#11 | |
82dB is too low for me, need bigger amp to drive. |
#12 | |
831 I mean 871. overall package is not cheap after you add in cabinet price, total price may exceed $300. |
#13 | |
How about this http://www.mcminone.com/product.asp?...me=MCMProducts Only a problem with it is a nasty peak starting at 10k, so it would need some kind of crossover with a helper tweeter to fill in that range. One thing about going full range is that there is nothing wrong with going with a helper tweeter above 10k or so, since the main advantage of going full range is getting rid of the crossovers in the vocal range |
#14 |
Even Tangband needs notch filter to tame the peak, however some reported no notch is fine. |
#15 | |
frugal-phile(tm)
A FR better suited to a SS HT receiver is the CSS FR125SR. I have a 4.5 liter box for these too. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#16 |
Thanks for all the responces. Now I have to look throught all the info and decide. The funny thing about the MCM aluminum drivers that were mentioned, is they are what is used in the Straight 8's speakers I built a long time ago as a kit from the Bottlehead company. I love the sound of those speakers, but they are a line array. I think if I could keep the pricetag for this project around $300 not including wood, that would be good. Thanks for all the help.
John |
#17 |
Dave,
Somewhere I noticed you were working on the micro Fonken. I went to your site and did not find any info. Do you have plans for these and how would they do for HT? Thanks, John |
#18 |
I support the HiVi B3N/S driver based loudspeakers as well; they're cheap, easy to build (Zaph's sealed enclosure or the mini TL that I built, for example) and although you need some power (more than Sonic T's and the like can provide) they can fill an average HT room pretty okay.
#19 |
I have both the B3S and the W3-871s. They're both great little drivers; I prefer the 871 but the B3s is very good. Without a filter the 871s is smoother. Though for movies can't go wrong with either one, especially if you plan on getting/making a sub.
Another good choice would be the Tang Band W4-1052s, assuming your receiver can handle a 4 ohm load. They are 4 inchers, reach to about 17khz and have punchy bass. I actually tried them in a box originally built for the B3S and though the sealed box is probably way too small for this driver it still sounded very good. Quite a bit more impact than the 3 inchers but it should have a bigger cabinet. |
| looking for help/ideas/info full speaker setup | Gprime | Multi-Way | 4 | 2nd January 2009 03:33 AM |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| i need a full range for max 50w | sexya | Full Range | 0 | 26th August 2007 03:58 PM |
| Advice on full range enclosure for 5.1 setup | CDJ | Multi-Way | 3 | 21st January 2003 05:28 AM |
| Page generated in 0.10403 seconds (78.97% PHP - 21.03% MySQL) with 10 queries |
