Hello,
anyone have a graph of the impedance of the Fostex FF225K driver in the BIB cabinet raccomended on zillaspeak site? thak you |
#2 |
here's a simulation of Z in half-space using AJ-Horn plus a comparison of that BIB vs the same volume but shorter (2.5M) concial horn to illustrate the tradeoffs. I think measured impedance may be off from predictions. I use half-space so frequency response can be checked with outdoor measurements to see how close a model might come.
note keeping the pipehorns volume fixed, the shorter horn has the upper bass advantage and vice versa with the longer horn. RCA-Fan (Bill Woods of AH!) ditched a larger/longer horn in favor of the 2.5M as the shorter horn was more accurate with cello. power input for sine has dropped to less than 1/10 of a watt on the BIB to reach 0.3mm xmax (we don't know the 70% BL figure - any guesses?) FF225K Z prediction http://img220.imageshack.us/img220/3...25kbib1jw8.gif FF225K BIB vs concial like RCA-Fan's k-slot blh http://img218.imageshack.us/img218/7...vskslotsq7.gif |
#3 |
meanwhile I tried to simulate with lspcad demo:
http://img440.imageshack.us/img440/8...5khrbibvk9.png looks very different. Did I set somethin wrong? I want to know the impedance to make the crossover. |
#4 |
at high frequencies the pipe's impedance effects will drop out and you'll just have the same Z as an unmounted driver so can use the published inpedance graph in Fostex's FFl225K literature. Voice coil nductance is very low and there's not much rise even at 10Khz. You could do a tweeter crossover by "ear". typical highpass capacitor values with an 8 ohm tweeter might be 0.68uF ->1uF.
at low frequencies a passive crossover to subwoofer could be tricky due to impedance interaction effects and parts expensive. AJ-Horn and MJK's Mathcad sheets will work for tapered pipes - - I don't know LspCAD |
#5 |
Greets!
Neither LspCad or any of the other standard box programs can sim a BIB nor can they predict the impedance without an inductance value (Le), so you're left with the factory's published plot to approximately calculate it: Le(mH) = [(Zxo^2-DCR^2)^0.5/(2*pi*Fxo)]*1000 Where: Fxo = some frequency point away from Fs Zxo = impedance at Fxo Dcr = Re GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
I also found this to calculate the LE
http://img444.imageshack.us/img444/8250/ff225klesu1.png So I use the impedance on the fostex graph to cross the tweeter. |
#7 |
Greets!
Since I get 0.226 mH using the formulas I posted, I don't recommend using this on-line calculator without multiplying its 'Henry' results by 1000 to get the labeled mH. Indeed, if you can, email them and ask them to review/correct it. GM
#8 |
So to cross the FF225K I use the published impedance.
Obviously for FT17H I use again the published impedance since it is a tweeter. And if later, a lot later, if I need more SPL I would like to add a woofer making a 3way I must use the impedance of AJ horn but using the LE value into simulation, right? Now I made a sim for a cross. It's a 2nd order cross with inverted polarity on the tweeter With diffraction sim ![]() schema ![]() without diff ![]() What do you think about? |
#9 | |
Looks good on paper! GM
| What impedance? | jaya000 | Multi-Way | 11 | 21st November 2008 07:04 AM |
| Impedance rate VS impedance stability | TomatoBangBang | Tubes / Valves | 6 | 4th September 2008 10:46 PM |
| Hi Vi SD1.1 impedance | guitarded | Multi-Way | 0 | 3rd February 2008 08:35 AM |
| Impedance and SPL.. | TroelsM | Multi-Way | 5 | 26th September 2005 12:52 PM |
| Need help understanding transformer impedance ratios and impedance matching | percy | Tubes / Valves | 5 | 28th February 2005 08:35 PM |
| Page generated in 0.11444 seconds (80.45% PHP - 19.55% MySQL) with 10 queries |
