Old 2nd November 2007, 02:23 AM   #11
Default Tweeters for DX3
From my experience:
Visaton Horn tweeter TL 16 H 8 OHM
Works well.
LCY 100K
Aurum Cantus G2
Raven R 1.1
These are not dynamic enough.
The Fostex horn tweeters (T90, T900, etc.) work well.
The RAAL ribbon 140-15D works well.
The RAAL and Fostex Magnesium diaphram tweeters are my favorites.
You have to add crossovers & padding to match.
As always, YMMV.
Jon Ver Halen
Lowther-America
Old 2nd November 2007, 02:34 AM   #12
ttan98 is offline ttan98  Australia
Visaton Horn tweeter TL 16 H 8 OHM works well
LCY 100K, not dynamic(ND)
Aurum Cantus G2 - ND
Raven R 1.1 - ND
The Fostex horn tweeters (T90, T900, etc.) workS well.
If I am not mistaken all these tweeters are fairly expensive except for Aurum Cantus...(less than US$90each). Also all of them are high quality tweeter.
My suggestion experiment with less expensive tweeter if you like the sound upgrade later. I would opt for Aurum first, which I am thinking of getting myself.
Bearing in mind earlier some purist don't use tweeter.
Old 2nd November 2007, 11:28 PM   #13
IMHO, the DX3 sounded better without the Aurum, it sounded as if the tweeter slowed down the system. It did, however, add just a bit of sheen on the highs.
With the preferred tweeters the system sounded like you made a nice addition to the sound, and nothing was lost.
Jon Ver Halen
Lowther-America
Old 3rd November 2007, 12:01 AM   #14
currently I use a Motorola Piezo(el cheepo tweeter does mean it is inferior, x-over at about 8K)), it seems to work quite well.
the other recommended tweeters are far too expensive for. Thanks for your suggestion.
I heard elsewhere that dome tweeters do not work as well with full range, is this correct?
Old 3rd November 2007, 02:48 PM   #15
I have yet to find a dome tweeter that is 97 dB efficient, so I have never tried one.
Jon Ver Halen
Lowther-America
Old 3rd November 2007, 03:10 PM   #16
most treble drivers have a dome somewhere in the air moving mechanism.
My Audax HD-3P and Tannoy HPD both have.
The dust cap in the middle of a coned driver provides much of the highest frequency output.
What shape is the diaphram of a compression driver? Domed?
regards Andrew T.
Old 3rd November 2007, 03:21 PM   #17
The Audax is a piezo unit, the Tannoy is horn loaded. I assumed the question related to a voice coil driven, direct radiating tweeter which is the typical definition of a dome tweeter.
If you choose to widen that definition all sorts of possibilities exist. But I never heard of anyone refer to a horn tweeter as a dome tweeter because there is a dome in the driver. Likewise, piezo tweeters are typically called piezo tweeters in order to differentiate them from "standard" dome tweeters.
Jon Ver Halen
Lowther-America
Old 3rd November 2007, 07:02 PM   #18
KMMM is offline KMMM  Norway
OK. That's all good.
Looks like I'll be trying The Fostex super tweeter.
One question though:
The Lowthers in the MLTL has a bump in Martin's frequensy response diagram - arround 7k to 15k in this design.
could this be the reason I get listening fatigue after a while?
After all it's at least 5dB.
The question is: would it be possible to dampen this bump?
Would it be best to cross over the Lowthers at 7-8k and then 8-9k on Fostex (ca 95dB)?
Then again may be there are better wways to do it?
Like leave it alone?
Best regrads
Kaare
Old 3rd November 2007, 07:16 PM   #19
I realize that the frequensy response diagram I've been looking at might not be
the final one...(?)
MJK made a revision to the Baffle Step Correction Circuit.
I made the updated one.
Is there an updated frequensy response diagram some where?
Are there a lot of difference in the new Correction Circuit?
http://www.quarter-wave.com/Project0...on_Filter.html
Could any one help me out here?
Best regards
Kaare
Old 3rd November 2007, 08:34 PM   #20
pdan is offline pdan  Europe
Hello Kaare,
In your first post you said you wanted to "bring a bit more sweetness from the music";is it possible that your drivers are not fully run in?
My experience with the EX3 is that they needed a good 6 months of regular use to run them in. Thereafter, they always sounded sweet to me.
Cilla
Adding a tweeter to full range gaust Full Range 50 21st November 2011 12:09 AM
Vintage FR BR ...adding a tweeter? waam68 Full Range 0 24th December 2008 12:39 PM
Adding a rear Ambience tweeter Jamesuk1 Full Range 4 23rd October 2008 06:55 PM
Impedance change for adding a tweeter? porkchop61 Full Range 4 16th September 2008 10:15 PM
Page generated in 0.10188 seconds (86.97% PHP - 13.03% MySQL) with 11 queries
