Bandor 50mm Project
Bandor 50mm Project
Old 7th February 2008, 04:00 PM   #21
inrank is offline inrank  United Kingdom
inrank's Avatar
to be honest i have not played around with the omni much recentley, just been using them normally facing forward, hence the interest in a small TL
Old 7th February 2008, 06:12 PM   #22
Colin is offline Colin  United Kingdom
You may be better off sticking to a sealed enclosure. I built an offset TL for the Jordan JX53s, based on the Augspurger tables. It sounded very thin. I later heard the same drivers on a wide baffle, sealed enclosure and it blew the TL away. All the lower mid and bass that was missing from the TL was back in spades.
Old 8th February 2008, 03:57 AM   #23
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Omni's are a bit different from normal design. If you measure the frequency response on these, the high would roll off, but quite well spread out. They generally have a relaxing sound, but not good imaging. This is also shown in the impulse response. I think any ported enclosure properly designed would be fine, but just don't expect them to play loud, especially with much low frequency content.
Hear the real thing!
Old 8th February 2008, 04:51 AM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Bandor 50mm Project
Originally posted by planet10
i've always wanted to play with some of those -- or the little Jordans.
I guess the Mark Audio version will do. A pair of those have appeared.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Bandor 50mm ProjectHide this!Advertise here!
For Sale (UK): Bandor 50mm and 150mm drivers Puggie Swap Meet 0 9th May 2009 09:20 PM
FS: 8 x Jordan 50mm module chibb Swap Meet 2 3rd May 2009 05:46 PM
Bandor 50MM Modules in a Sub-Sat System Karl71 Full Range 13 20th September 2008 11:04 PM
Bandor 50mm inrank Full Range 1 7th January 2008 12:10 PM
