Has anyone ever built a full range center channel, specifically one that is small enough to fit in the drawer-size aperatures? I have some Foxtex 208EZ's in a folded design that work really well, am hooked on the full-range concept and benefits.
Am looking for something that could fit in 22.5" wide x 18.5" deep x 5.5" high finished opening. Guessing this limits me to 4" units or less. Perhaps multiple drivers? Thanks for your help, DV |
#2 |
frugal-phile(tm)
You could fit an FE127 box in there...
dave BTW. The correct transliteration of FE208e∑ is FE208eS (eZ is someone at Madisound not familiar with the Greek alphabet)
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
I asked almost the same question a little while ago.
I received some good help here: Centre speaker to match Fe207E Spawn BVR should be exactly what you're looking for. I'm ashamed to say I havent even ordered the driver yet. |
#4 |
Would it be possible to use one of the double horns on its side as a centre speaker, this could be discorporated into a TV stand also, and thus match the L & R channels better, and some smaller double horns for souround.
I am thinking of going this way if I get a living room big enough, say FE166's for souround and centre and FE207's for left and right with possibly a shadow sd12 (or 2) for a bit of low frequency umph. A class D or chip amp output AV reciever would possibly be acceptable to drive them. One day. |
#5 |
Yes, you could do that easily enough. Don't forget FR units are quite directional so it'd depend on the unit as to how well it will perform, as obviously you'd be off-axis.
#6 |
Must re-think the centre, posibly along lines of the thread Mike has listed above. I have used the FE166's for film and must admit it quite good. My only real foray into Home Cinema in the last 10 years or so was a cheepo (about £300) all in one system that I won. We set it up and was initialy impressed, for about 2 films, then we all realised how fatiguing the sound was, boom boom bass, shrieking midrange. So my next foray into home cinema will be with some CC's for front L&R and the FE166's for rear, when I've got some room of course.
I presume the of axis is the reason they tend to use multiple drivers for the centre speaker. |
#7 | |
frugal-phile(tm)
Note that with digital TV something like a minimum of 4-5 screen heights is the recommended minimum viewing distance. dave
#8 |
While the FE208eS might be the correct transliteration of "E" Sigma, the FE208ES is a different driver entirely...
so to cut back on confusion, perhaps I have always thought that the Z works for keeping things straight (or rather, properly crooked). Clark
Http://blumenstein-ultra-fi.com |
#9 | |
frugal-phile(tm)
dave
#10 |
That photo shows the results of some serious spouse acceptance factor negotiations.
A huge rack of gear, big BLHs and a subwoofer, All covered liberally with frilly fluffy dolls, figurines and doilies. Audio is ALL about compromises. Love it. |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| not really a full ranger | Nanook | Full Range | 3 | 3rd April 2006 08:20 PM |
| Which full ranger for 3L sealed? | noobsta | Full Range | 3 | 20th January 2006 12:37 PM |
| Foam blocks between 2 Tang Band 3" full range on a small center channel | The Paulinator | Multi-Way | 5 | 27th March 2003 05:04 AM |
| Page generated in 0.10830 seconds (81.98% PHP - 18.02% MySQL) with 10 queries |
