I'm interested in trying a FR driver, and I am considering building a Fonken as a first speaker project.
1) In regards to the Fonken and amplifier output impedance, what is a suitable value/range? I'm going to be building a SE amp (which should have a nice high output impedance), but my VTL EL34 PP amp has an OI of 1.6ohms. Is that in the right range for the Fonken? 2) Has anyone designed a "low freqency box" to complement the Fonkens, much like the wilson watt/puppy two-box design? P.S. Planet10, any update on the Fonken flat-paks? (My woodworking skills are decent, but I left my table saw and router with my parents when I moved to NYC....) |
#2 |
Your VTL EL34 PP amp (IT-85?) should sound fine with a pair of Fonkens. Not sure why you want to build an amp with high output impedance?
Read this. BTW, my Fonkens sound much better running off the 4 ohm tap than the 8. Try PM'ing Dave directly regarding flat packs. Jeff |
#3 | |
From the Planet10 website: The Fonken likes small amps with highish output impedance like SETs, no-feedback push-pull. a whole new wave of single-ended SS, and the new small digital amplifiers. Becuase they are ~6 dB more efficient you can get away with not much power -- 2-20 watts is fine. The miniOnken likes larger class A & Class AB PP amps with low output impedance -- typical receivers & solid state amplifiers as well as push-pull tubes amp with feedback. My VTL ST-85 (great amp!) falls into the latter category, as it is a Class AB PP amp. But, 1.6ohms strikes me as a rather high output impedance, more in line with some of the SETs, I think. |
| Fostex FE127eN / Fonken Floorstander Mk II Questions | N1ESE | Full Range | 3 | 15th November 2008 10:36 PM |
| Fonken Build Questions | cgrums | Full Range | 3 | 17th October 2008 12:54 PM |
| Fe127/Fonken driver mounting questions | strider75 | Full Range | 8 | 14th August 2008 05:56 PM |
| Finally done, Fonken | kazoo | Full Range | 13 | 21st November 2007 09:45 PM |
| Fonken Questions | widman | Full Range | 0 | 23rd August 2006 12:08 AM |
| Page generated in 0.07950 seconds (72.81% PHP - 27.19% MySQL) with 10 queries |
