hi,
perhaps I am not the first person asking - but did not find anything through searching: does anybody got an idea or recommendation for some idea for a reasonable full range speaker or construction plans to build some kind of portable speakers (portable as in put in your laptop bag)? thanks in advance marcus |
#2 |
Peerless 830986 3"
http://www.tymphany.com/datasheet/printview.php?id=369 Peerless 830970 2" http://www.tymphany.com/datasheet/printview.php?id=357 http://www.madisound.com/catalog/pro...oducts_id=8267 HiVi B3S 3" http://www.partsexpress.com/pe/showd...number=297-427 http://www.zaphaudio.com/smalltest/ (scroll down) Aura NS3 3" http://www.aurasound.com/ http://www.aurasound.com/public/pdf/NS3-193-8A.pdf http://www.zaphaudio.com/smalltest/ (scroll down) * All versions of the NS3 are sold out at Madisound.. http://www.madisound.com/catalog/pro...oducts_id=1372 http://www.madisound.com/catalog/pro...products_id=83 http://www.madisound.com/catalog/pro...roducts_id=773 http://www.madisound.com/catalog/pro...oducts_id=1400 Several of the Tang Band units should suit this application, although the only ones I have any experiences with are the popular W3-871S 3" and W4-1337SA 4", which are both well-known and recommended. It appears as though the W3-871S has changed to W3-871SC, but I'm unaware of the specific changes made. http://www.tb-speaker.com/p1.htm Tang Band W3-871SC 3" http://www.tb-speaker.com/detail/1208_03/w3-871sc.htm http://www.partsexpress.com/pe/showd...number=264-813 Tang Band W4-1337SA 4" http://www.tb-speaker.com/detail/1230_04/w4-1337sa.htm http://www.partsexpress.com/pe/showd...number=264-848 http://www.zaphaudio.com/smalltest/ (scroll down) And of course, the small Fostex full ranges. Here are just some 3" Fostex drivers. If you want any "bass" response whatsoever in the smallest enclosure possible, a Tang Band or Aura might be a better choice. However, any of the Fostex drivers will be much more sensitive though, and be able to play at fairly high volume levels with just a few watts... Fostex FE83E http://www.madisound.com/catalog/pro...roducts_id=276 Fostex FE87E http://www.madisound.com/catalog/pro...roducts_id=277 Fostex FF85K http://www.madisound.com/catalog/pro...roducts_id=281 Hope this helps a little. Goodluck with your project. ![]() /Brandin |
#3 | |
That sounds very interesting! Thanks a lot. Using effective drivers make a much easier choice for the amplifier (perhaps even some strong headphone amps? - nice dual purpose). Thanks a lot! |
#4 | |
http://www.amazon.com/Sonic-Impact-1.../dp/B00009W44B http://www.partsexpress.com/pe/showd...number=300-958 |
#6 |
Well, I'm just starting a simple fullrange build for a set of tiny computer speakers, and I found that there simply isn't a small enough design that sounds good using a 3" woofer. The best I've seen was Zaph's B3s (http://www.zaphaudio.com/audio-speaker18.html) but the baffle was 5"x9" and I needed something closer to 3"x3". I've settled on using a pair of Aura NSW2s, and designed a compact box that matches the Vas on the spec sheet. http://www.aurasound.com/public/spea...ents/body.html
I'm using these in a very quiet setting (played at sub 60dB), so I think I'll be just fine. I haven't seen this speaker used much anywhere, so I figured I'd give it a shot. Any comments are welcome. |
#7 |
I want to first thank brandon for his post #2
I made small speakers with fe87e and a peerless passive radiator. i like how they sound but I have no test equipment. not a lot of sub bass but musical instruments sound very good. |
#8 | |
NOTE: you have to scroll down to post 19 to see the aura design. Spudfrog's computer speakers Squib |
| DIY Portable Speakers? | fury | Multi-Way | 17 | 5th November 2009 06:20 PM |
| Powerful small/thing portable speakers? (battery powered?) | Anirak | Everything Else | 2 | 24th March 2009 09:29 PM |
| Low-end small portable speakers for travel - build or buy? | larry_long | Full Range | 11 | 30th December 2008 02:52 AM |
| Small Portable Speakers and a T-Amp | guitarobert | Full Range | 2 | 24th January 2008 06:40 PM |
| Wanted: External, portable CD-ROM or DVD drive; decent USB DAC, portable speakers. | Spasticteapot | Swap Meet | 0 | 31st May 2006 02:13 AM |
