Old 11th October 2007, 01:47 AM   #1
Default FR125S with Gainclone?
I've been reading some great things about the FR125S driver. Can anyone tell me whether this speaker could be driven satisfactorily by an LM3875-based gainclone? What about an LM3886?
Old 11th October 2007, 02:43 AM   #2
ruerose is offline ruerose  Canada
I run mine off a Sonic T-Amp (15W/ch), enough power for near-field and low-moderate volume (85dbc-ish on pop music) mid-field listening. (smoking awesome sound quality)
I had them hooked up to a 50w/ch Panny digital HT reciever, but any louder and they started breaking up anyways. (the panny is a little harsh sounding with these as well)
So if you using them in a near-field application, I would say it should be plenty. Even mid-field they should have enough juice for quiet-critical listening. Just don't expect to rock the house with a driver this small. My listening environment is rather quiet at as well.
Old 11th October 2007, 03:00 AM   #3
I use exactly this combination i.e. 3875 with FR125 based speakers. I am really pleased with the sound.
Rob.
Old 11th October 2007, 03:05 PM   #4
If I do want something that I can turn up kind of loud occasionally, is there another driver that might be better suited to the task? I'm not trying to wake up the neighbors or anything, but I'd like to be able to fill up my living room with sound.
Old 11th October 2007, 03:12 PM   #5
Scottmoose's Avatar
That would depend on how large your living room is.
If you want some scale & like to turn the wick up a bit every now & then, I'd be looking at a pair of FE167Es. Not as delicate or holographic as the smaller drivers, but they can shift a bit more air. They're my current FR reference unit, in my own MLTLs.
Old 11th October 2007, 03:50 PM   #6
Speakerholic
Cal Weldon's Avatar
I'm with Scott and the others. Great little driver but meant for critical listening not party time.
Is there enough in the budget to do both? You can find some cheap pre-built party speakers and keep them in the closet until needed.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 11th October 2007, 06:53 PM   #7
Would a bit of gain at the preamp stage help to get a little more juice to the FR125?
Old 11th October 2007, 08:12 PM   #8
Scottmoose's Avatar
Probably, but your main problem if you want room-filling is the small cone area. They just don't shift enough air.
Old 11th October 2007, 10:40 PM   #9
diyAudio Moderator Emeritus
Bas Horneman's Avatar
It is sufficient to use an LM3875 especially near field or small room. But I've found that something that can deliver more current/power like a Rod Elliot's p3a for example makes them come to life.
Old 12th October 2007, 04:56 PM   #10
I think this is probably what I'll end up doing. Can anyone recommend a transformer for powering the FR125S from an LM3875? This will be a monoblock amplifier, if that makes a difference.
Fr125s Bib cangaceiro99 Full Range 16 26th August 2008 06:16 AM
My take on FR125S in OB Rafal Full Range 37 22nd March 2008 10:20 PM
CSS FR125S 2 way OB Rafal Full Range 19 10th October 2006 03:56 PM
css fr125s joe perry Full Range 5 10th May 2006 04:11 PM
FR125S in TL? robertG Full Range 37 27th March 2006 03:58 PM
Page generated in 0.09623 seconds (80.65% PHP - 19.35% MySQL) with 10 queries
