Really basic TL question
Old 10th October 2007, 07:15 PM   #1
weinstro is offline weinstro  United States
weinstro's Avatar
Default Really basic TL question
Hi all,
Suppose I have a sealed enclosure, with an appropriate driver mounted. I used one of the many box size calculators to arrive at the enclosure size, aiming for a Qtc of 0.7.
Now suppose that one dimension of the box happens to equal the quarter wave length of the driver's Fs. Volume is unchanged from above, but the box is a tall column.
What happens? How would the performance of the driver differ from that predicted by say, Unibox? Does it matter where the driver is mounted?
Old 10th October 2007, 08:33 PM   #2
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
Yes, it will make a difference where the driver is mounted. In effect, assuming it's stuffed properly, what you have there is a 'real' transmission line, rather than the more usual aperiodic lines, or mass-loaded lines. Will the differences be significant? Depends on the driver & cabinet. What exactly are they?
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 11th October 2007, 05:08 AM   #3
GM is offline GM  United States
GM's Avatar
Greets!
Assuming the box is still sealed, then there will be 'room' modes beginning at 1/2 WL with a deep notch at every harmonic, so its response will be tuned lower and anything but smooth. Driver placement makes a big difference with the midpoint yielding the smoothest, though still relatively ragged response which stuffing will smooth out to a great extent at the expense of a much higher F3.
Bottom line, not a good plan IMO.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 11th October 2007, 06:16 AM   #4
Shae is offline Shae  Australia
woops wrong thread
Really basic TL questionHide this!Advertise here!
amp question basic rec rebith75 Solid State 3 16th March 2007 06:43 PM
Basic RC Value Question SRMcGee Tubes / Valves 6 13th August 2006 06:39 PM
really basic question cuallito Tubes / Valves 6 15th April 2004 09:25 PM
Basic question Tommy Solid State 6 22nd February 2004 04:08 PM
really basic question MbayAQ Digital Source 3 7th January 2003 01:57 PM
Copyright ©1999-2017 diyAudio
