what about sealing the enclosure?
Old 9th October 2007, 06:08 AM   #1
gnugear is offline gnugear  United States
Default what about sealing the enclosure?
Okay, after the many helpful responses in the "why MDF thread", I went out and bought some seven ply birch ply to build my enclosure.
I have a feeling I'll be experimenting with damping material so I'm wondering what you guys do to easily cope with this process. Is it okay to simply screw the "final" side in place so you can access the compression chamber and throat? Is it better to glue all the sides and then stuff material from the insides?
Sorry again for all the questions but I'm a total noob and I've determined that this site rules!
Old 9th October 2007, 09:16 AM   #2
germpod is offline germpod  United States
Which enclosure are you building? Some enclosures are easier to get into through the driver hole than others. If you are building Harveys than you just take the driver out and stuff to tasts, but if you are building a enclosure with multiple folds inside than you have to figure out something else.
Old 9th October 2007, 10:32 AM   #3
Nanook is offline Nanook  Canada
Nanook's Avatar
Default gnugear...
the Heruka horns look as though there is no dampening in the horn itself. If you want to add dampening, then the most likely locations (the compression chamber and the horn as it approaches the mouth) are accessable from the driver hole and the mouth. I'd dowel the final side on and glue and clamp it if possible. With relatively thin interior panels, the likely hood of a screw missing the horn panels is pretty high.
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
what about sealing the enclosure?Hide this!Advertise here!
Paint damage from sealing drivers with silicon, what to use for sealing drivers? DexterMorgan Multi-Way 21 12th February 2009 12:46 PM
Sealing enclosures dsavitsk Full Range 4 17th January 2009 08:13 PM
Jordan MLTL Enclosure Sealing LizardBrain Full Range 10 24th March 2006 10:50 PM
Sealing a driver to the baffle dscline Subwoofers 11 10th January 2006 03:25 PM
sealing around drivers nobody special Multi-Way 4 6th February 2003 07:18 PM
Copyright ©1999-2017 diyAudio
