Martin King's MLTL-48 for jx92
Old 25th October 2007, 03:29 PM   #21
keladrin is offline keladrin  United Kingdom
Hi GM,
I am using a helmoltz resonance calculator and it definately says that you need to double the vent length and area for the same tuning frequency for double the cabinet volume (which you would need to do for 2 drivers). Where am I going wrong then? Is this not true for MLTL?
Keladrin
Old 25th October 2007, 04:29 PM   #22
GM is offline GM  United States
GM's Avatar
Greets part deux!
I don't know what you may be doing wrong, probably nothing other than needing to use a different calculator , which BTW will typically calc a too long vent in a MLTL since it doesn't factor in the MLTL's high aspect ratio TL loading on it, making it shorter for a given Fb WRT a simple golden or acoustic ratio cab. For best accuracy you'll need to use MJK's MathCad software or probably AKABAK. There may be others, but for sure all the free mainstream box programs I'm aware of can't do it.
Anyway, let's look at it this way and see what your program calcs...... with 2x the drivers, Vb and the same Fb, input a single vent of 2x the area of one (i.e. original diameter*~1.4142) and you should get a slightly shorter vent length than the one it calcs for the original single driver alignment. This is due to less friction compared to using two of the original diameter vents. If it does, then how can using two of the original diameter vents be twice as long?
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 25th October 2007, 06:10 PM   #23
Thanks GM. I will try one of the calcs you recommend and start from scratch.
Keladrin
Old 28th October 2007, 07:58 AM   #24
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Does the calculator account for 2 drivers?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Martin King's MLTL-48 for jx92Hide this!Advertise here!
martin j king's sheets bigcatdairy Multi-Way 8 31st October 2008 09:19 AM
help designing an martin king TL matjans Multi-Way 7 17th November 2003 02:11 PM
Martin King's Lowthers planet10 Multi-Way 13 14th November 2002 11:19 AM
