diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   The elusive Horn...can I have it all? (http://www.diyaudio.com/forums/full-range/109451-elusive-horn-can-i-have-all.html)
Fast1one 3rd October 2007 08:46 PM
So I have built nearly every possible enclosure, or have atleast heard a good example of it.... Except...
Horns, specifically BLHs. I'll cut straight to the chase. I don't want to deal with a sub anymore, but I want most of the low frequency response to be in tact (IE as low as I can go). I was looking at the pioneer B20, or another 8 inch FR driver in that price range. Doesn't matter how much wood is used so long as I can use 2x4 feet project sheets as I don't have a truck right now. Complexity isn't too much of an issue either so long as I can use a table saw to do all the cuts.
What I am looking for is full range response from 20(30)HZ-20K. A helper tweeter will be used to fill in the upper octaves. I have about 15-20 watts to work with. Also, currently my room is too small to support anything under rouughly 30hz, but I want a response lower than that for headroom when I move into a larger space...
Is it possible? If you have any other suggestions for drivers, Im trying to keep the costs of drivers ~60 plus the cost of tweeters, so anything with an efficiency of 90db or more I can work with...
Thanks for any help or responses :)
-Serg
Scottmoose 3rd October 2007 09:13 PM
A BIB pipe-horn with an 8in driver like the B20 should do the trick. Small is not a word that immediately springs to mind with this cabinet though.
Fast1one 3rd October 2007 09:17 PM
That was my first option, but the problem (which I forgot to mention) is that I usually don't have corners to work with, not to mention I want to keep it relatively short. Which is why the Suzy chang caught my interest.
One alternative I thought of is building a BIB with two folds instead of one and either floor loading it or firing it towards the wall...
GM 4th October 2007 01:09 AM
Re: The elusive Horn...can I have it all?
Originally posted by Fast1one
Is it possible?
Considering all your qualifiers and no corners, I don't see how.
Fast1one 4th October 2007 03:59 AM
Would folding BIBs with two folds give a noticeable drop in performance? I may just do that...It doesn't have to be small just short :D
Edit: I don't have to have response that low, because I know the real world is not perfect, just want to get as close as possible, maybe when I move in to my house I will have corners :)
GM 4th October 2007 04:27 AM
Hard to say, it just depends on how much, if any, extra damping is required.
Fast1one 4th October 2007 04:30 AM
Im thinking if just building the Suzy Chang for the B20, and adding stereo bass later if i really want to....Its so easy to build a chimp can do it, of course I always wanted to build a BLH :) But we can't always get what we want...
planet10 4th October 2007 05:18 AM
Suzy Chang is for FE107 (FE103). Half Chang is for B20.
dave
Scottmoose 4th October 2007 10:57 AM
Oook. Gibber. Scratch. etc. :D
In that case, I'd forget trying to go for 30Hz or lower. Go for 40Hz (which is as low as acoustic instruments, pipe-organs aside, go), and then add a couple of subs at a later date. If the box gets a little below 40 as is, bonus.
Circlomanen 4th October 2007 11:49 AM
The Decware Imperial with a B&C 15CX40???
Big BLH/BVR
15 Inch coaxial
If you will use a tweeter with a Fostex, you can just as well have the tweeter i the center of the bass-cone.
Copyright 1999-2017 diyAudio
