In several posts I have read things like, "...may need a suprabaffle" or "... this could befefit from adding a suprabaffle", etc.
Assuming the baffle is round (I know there can be other shapes, but I'm starting with round), how much bigger do you make the baffle than the driver? e.g. If the driver is 6 inches, the baffle should be 9 inches. How thick do you make the baffle? e.g. If you are using 18mm ply for the cabinet, use 36mm ply for the baffle. The Fostex FE127E (and I assume most speakers) benefits from the having the hole chamfered to allow "breathing room" for the driver. If you double the thickness of the baffle by adding a suprabaffle, there won't be much room for breathing. Does the hole in the enclosure need to be larger than the hole for the driver? How is the suprabaffle attached to the baffle?
Any other options? |
#2 |
I went for option No. 1.
The big deal is actually not the details you've mentioned, but to make the baffle itself. It needs to be made with a decreasing radius as you approach the outer edge. Now that's hard to do if you don't have some computer controlled machinery. Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#3 |
Yes. A thirty (30) degree angle cone appears to work best. It needs to be made with a decreasing radius as you approach the outer edge. Well, yes and no. In a trapozidal baffle if there are trailing edges the wave wraps around and edge diffraction is sent rearward. If you reduce in area from the trailing edges, rearward, this would emulate an aerodynamic shape where the diffraction would be attenuated over the surface and end up at a point rearward. In a perfect world it would be shaped like a water drop travelling thru the air and coming to a point at the rear on the outside contour. However it would take an extensive build to accomplish that. ron |
#4 | |
#5 | |
It means that the radius of the face of the baffle should be a Log function. Magura
#6 |
#7 |
Account Disabled
nickel, thanks for that!
#8 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
| Make it worse to make it better??? | moray james | Planars & Exotics | 23 | 12th May 2008 11:08 AM |
| Help me to make something out of a old sub | Mr.Mekulic | Subwoofers | 6 | 9th March 2007 03:54 AM |
| help me to make my own box | tobler | Multi-Way | 1 | 3rd July 2005 04:13 PM |
| How make make a microchip, from a program? | multiplexor | Everything Else | 1 | 20th February 2004 01:24 PM |
| Page generated in 0.10287 seconds (86.39% PHP - 13.61% MySQL) with 11 queries |
