Old 25th September 2007, 06:59 PM   #1
Default Dallas 2 building material question
I have a quick question about the thickness of ply for the above enclosure.
I can’t source 18mm (0.7in) ply where I live, but I can 15mm(0.59in). Is 15mm ply thick enough? Will it ring, or resonate to much? Has anybody built a Dallas2 with thinner ply?
I’m planning to put an extra back board to strengthen the enclosure, and fill all the voids with sand. I’m using ply made of beech, (http://en.wikipedia.org/wiki/Fagus_sylvatica) that is supposed to be the strongest, densest ply around these parts(850kg/m3).
I was planning to scale the plans to 15mm wood so that all the internal dimensions of the enclosure stay the same. Is this the correct way to do it ?
Any feedback from Dallas2 builders is appreciated.
Old 25th September 2007, 11:11 PM   #2
ronc is offline ronc  United States
Shouldnt be a problem, just hold the inside to print dimensions.
ron
Old 26th September 2007, 10:30 AM   #3
mavallarino's Avatar
Default Dallas 2 Design
Hello Mr.Mekulic,
I've seen this Dallas2 in photos on this site. What is the design you are using and where have you found it? Is there a plan with dimentions and information?
Thanks, MV
Old 26th September 2007, 03:14 PM   #4
Default Re: Dallas 2 Design
Originally posted by mavallarino
Hello Mr.Mekulic,
The plans are on the bottom of this page (pdf)
http://www.frugal-horn.com/ronhorns.html
http://homepage.mac.com/tlinespeaker...asII-plans.pdf
That is all I found, if anybody has any other plans please post.
carbon fiber as a building material? stuman Multi-Way 18 22nd April 2009 04:18 AM
What do you gents think about building a box with this material? tf1216 Multi-Way 14 28th October 2008 08:47 PM
Page generated in 0.07842 seconds (75.85% PHP - 24.15% MySQL) with 10 queries
