Hello,
I have one Fostex FF225k that could be faulty. The speaker sound distorted. I tried everything with wiring. If you have any ideas..... otherwise I will change the speaker.
thank you
PS
When I turn on the amplifier the speaker emit a low tone bump and has a big cone excursion. The other speaker doesn't have that excursion, but it has the normal middle pitched bump( so normal).
thank you
PS
it may be the amp, the speaker or the source. not too long ago i ordered a replacement 127e because i thought it was blown. The new driver arrived and had the same problem (similar to what you describe). Turned out to be one channel on the CD player.
Check the driver on the side that works and see if it still sounds busted. If its ok, then it's the amp or the source.
Good luck!
Godzilla
Good luck!
Godzilla
yes I have swapped channel: same result.....
Exchanged speaker cables L > R and R > L in either speaker or amplifier end and still problem in the same speaker?
- Full Range
- faulty driver?
