I bought a pair of Fostex FE127E speakers for my new found hobby. Upon receiving them I decided to temporarily stick them into one of my cabinets just to break them in and get a feel for their sound. I pulled the woofer from my Genesis II+ cabinets and modified (if you can call it that) the baffle. I'm floored by how good they sound in these boxes. Detail without extended highs which is good for me since my ears have taken a lot of SPLs as a musician. They (ears) just don't like volume or lots of treble. At this point I've abandoned my desire to build cabinets because these sound so good. They are 1.9 cubic ft with a passive radiator. Can those of you who understand this kind of thing explain why this works?
#2 |
frugal-phile(tm)
Hmmm... blind luck?
Are the 127s fresh out of the box? You may find that the box tuning shifts as the drivers break in. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 | |
Yep. Brand spankin' new. In what way might the tuning shift? |
#4 |
Greets!
At 1.9 ft^3, a 127E is working into a 'close enough' infinite baffle, so I imagine its motor isn't strong enough to energize the PR very much, making it a well damped, probably well below Fs tuned TL of sorts. I use to periodically mention using PRs to smooth TLs when excessive damping is required, but been poo-poo'd by some who apparently have never tried it, so maybe now that someone has backed into it with good results will spur others into trying it. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
'Never heard of the idea until now Greg, but it makes sense to me. I assume you mean placing the PR at the terminus of the line, right? Certainly an interesting take on it.
#6 |
Right.......I'm not much of an original thinker though, it was an Olson idea as a way to shorten a BLH (RCA LC9A with (3) PRs), so using it in a TL or TQWT wasn't much of an intellectual leap.
#7 |
I remember the sound from those Genesis was really good. Heard them at Stereo Warehouse in Roosevelt Field mall many years ago. They had a very full and warm sound. How did the sound change when you put the Fostex in? More detail? More forward?
I would put the Genesis back the way they were and build a more optimized cabinet for the lovely 127e. Not that what you did doesnt sound good. It's difficult to make the 127e sound bad imo. I always wanted to try a PR because they are cheaper than woofers. |
#8 | |
I was starting to grow tired of the Genesis' lack of midrange. To my ears this has been a huge improvement not to mention the increased detail. Someday I'll probably want to build cabinets but not until I'm convinced that I'll hear an improvement. GM - you are right about the PRs not resonating very much with the FE127Es. |
#9 | |
frugal-phile(tm)
A technique used commercially in some of the the Shahinian Acoustics boxes. http://shahinianacoustics.com/ dave
#10 |
This sounds like an interesting idea. So could one take an MLTL and add a passive radiator in instead of the port? Would the box need to be redesigned with this in mind?
| LED lights...Surprised | gmphadte | Parts | 4 | 7th March 2007 02:57 AM |
| CCS, how it actually works? | timf | Tubes / Valves | 17 | 23rd January 2006 12:20 AM |
| It works .... | jcayer | Pass Labs | 3 | 28th February 2005 01:00 AM |
| Page generated in 0.09837 seconds (80.59% PHP - 19.41% MySQL) with 11 queries |
