Old 13th September 2007, 02:06 PM   #1
jnb is offline jnb  Australia
Default Widerange Mid/Tweet suggestions
I'm looking for a single driver of some sort to handle around 400Hz and up. If dynamic, then I would want to use it as a dipole though other types may be appealing. I'd like to avoid something that has a 'shouting' characteristic if possible, unless there is a known fix for it.
I would be crossing over actively to 15s.
Old 13th September 2007, 02:29 PM   #2
PigletsDad's Avatar
On paper, the Jordan JXR6 would fit your requirements, if it will give you enough output.
I haven't heard one, so can't comment on the shoutyness or otherwise.
Old 13th September 2007, 02:32 PM   #3
Did it Himself
richie00boy's Avatar
One of the HiVi 2 inch drivers? They are cheap too.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 13th September 2007, 03:03 PM   #4
DonoMan is offline DonoMan  United States
Send a message via AIM to DonoMan
I'd want to go for at least the 3" to go down to 400Hz unless you don't want a lot of volume...
Old 13th September 2007, 03:33 PM   #5
Scottmoose's Avatar
Personally, I'd go with a JX92S, Fostex FE108ESigma, F120a or FX120.
You're pushing those 15in units a bit high though IMO -FWIW, I wouldn't take them up past 200Hz, maximum. Those big cones don't like going much higher (big co-ax unts excepted). And unless you're very careful, vocal imaging might suffer a bit with things coming rather obviously from two different points. That's just my take on it of course.
Old 14th September 2007, 01:51 AM   #6
Originally posted by Scottmoose
Personally, I'd go with a JX92S,...
I have looked at this driver and they say that it has better bottom end than the Jxr6. Since I need that less, I wonder if I'd get better mid/top with a Jxr6?
Old 14th September 2007, 05:52 AM   #7
ashok's Avatar
Is there an upper bass/ mid driver ( 5 inch ?) that is flat to about 5 Khz with no peakiness after that ? Like the Vifa P13W 5 inch driver . With enough Xmax to be used in an OB . I guess 24db ( linkwitz) crossovers will help in limiting the X max requirement .
How good are the new 5 inch Peerless or other similar drivers ?
AM
Old 14th September 2007, 08:02 AM   #8
Did it Himself
I'd say yes.
Old 14th September 2007, 08:28 AM   #9
Scottmoose's Avatar
Probably -again, I'd be very wary taking 15in units up that high though.
Old 14th September 2007, 10:32 AM   #10
tinitus is offline tinitus  Europe
I think ALL woofers present a problem above 300hz, even 8in will ... it needs great care in xo design to integrate properly ... in that respect I dont think that even a good 18in studio woofer will be much different ... it just needs great care in xo design, and proper choice of other drivers
I dont know why, but I am not sure if those small light coned low wattage drivers are good with active xo
Although this 8in Fostex is also light coned and low wattaged, it does have higher sensitivity, thus will need much less power and be less strained
http://www.fostexspeaker.ch/fullrang...rie/ff225k.pdf
Suprabaffle for widerange + tweeter? fred76 Full Range 3 3rd May 2007 06:57 AM
Ribbon Tweet suggestions.... eastcoast Planars & Exotics 0 28th March 2005 07:33 AM
Two new widerange drivers at madisound morbo Full Range 8 22nd December 2004 09:26 PM
Widerange drivers and EQ morbo Full Range 10 4th November 2004 06:19 PM
Widerange Driver 2-Way project LageB Multi-Way 1 30th March 2004 06:58 AM
Page generated in 0.10510 seconds (79.38% PHP - 20.62% MySQL) with 10 queries
