need tips for monacor sp200x
Old 10th September 2007, 07:02 AM   #1
tyor is offline tyor  Norway
Default need tips for monacor sp200x
HI
I have a pair of sp200x http://monacor.no/hoyttalerelementer...lltone/sp200x/
Now in a folded voigt pipe. The sound is ok but I want try somthing new with them.
So What should I try?
Old 10th September 2007, 07:38 AM   #2
Svein_B is offline Svein_B  Norway
I have seen sp200x suggested for open baffle (as a lower price alternative to the Visaton B200), but Qts=0,52 might be on the low side for OB.
Why not tell us what you would like to improve, and a photo or plans of the existing cabinets. If the cabinets are worth keeping, it may be possible to modify the cabinet to some TQWT or TL alignment.
SveinB.
Old 10th September 2007, 07:43 AM   #3
hpolkerman is offline hpolkerman  Netherlands
Hello,
I've got four of them and there are several options:
BR - from 50 Liter till a 100 (more liter the beter, I'm thinking of 70Liter would be nice)
TQWT (Tampered line) If you need the scetches I've got some images from an old forum that isn't around anymore. They should sound great with a deep bass and aren't as big as the 100Liter BR's...
Double BR (As the Visaton Solo 50 and 100)
Open baffle, not my favourite tried it once...
Horn, haven't tried it yet.
In short I'm going to build the BR-70Liter with them and a TQWT just for fun... But first I'm going to finish some old projects I've got lying around.
The SP-200x needs notchfilters, you'd best should use 1.5Mh, 2x22Ohm 10Watt, 2.2uF in parallel of each other in a serie on the SP200x.
In addition a supertweeter would be a good idea to get some high out of the speaker... with a 8.2Ohm resistor in parallel and a 1.5uF 400Vdc in series of the tweeter.
Hope this helps, Gr. Henri
Old 10th September 2007, 07:45 AM   #4
I want to have a little more bass if possible. vil give you a drawing of the cabinets later today. But the cabinets are not worth keeping. they are awfull
Old 10th September 2007, 02:49 PM   #5
Leglandu is offline Leglandu  France
Default my 5 cents...
Here is a TQWT drawing, from a french forum :
http://www.cinetson.org/phpBB2/viewtopic.php?t=8512
Note they add a SPM-90, glued at the back of the driver, to increase the HF :
http://www.monacor.com/int/en/produk...pr=EN&typ=full
To be glued as opposite field, preferably whith a 3 mm spacer...
Old 10th September 2007, 03:54 PM   #6
Another way, "Quasi.Mo.D.O" :
http://melhuish.org/audio/DIYBX8.html
Old 10th September 2007, 07:00 PM   #7
Default Re: my 5 cents...
Hmmm That TQWT looks like the speakers I have. I thought it was a folded voigt pipe
But I dont have that filter and I have to look at my draving about the size of the cabinet.
Old 11th September 2007, 06:04 AM   #8
I have desided to try some kind of rear loaded hor. Any sugestin of what kind and size that will fit to this driver
Old 11th September 2007, 09:32 AM   #9
If you can afford big dimensions, the BIB is just for you :
http://www.zillaspeak.com/bib-howtobuild.asp
http://www.zillaspeak.com/bib-pics.asp
http://www.zillaspeak.com/BIB-Monacor.asp
It will be about 178 x 42 x 29 cm external...
The original is there :
http://melhuish.org/audio/DIYTQ8.html
And THE dedicated huge thread to get more infos/help :
http://www.diyaudio.com/forums/showt...threadid=66173
Old 11th September 2007, 03:52 PM   #10
veryy intresting. and easy to bild. The cabinets I have look like this http://melhuish.org/audio/DIYTQ3.html
And They are 100cm high. 20cm width and 40cm deep.
If I build BIB with sp200x. Should I use some kind of filter?
need tips for monacor sp200xHide this!Advertise here!
What about Monacor? mr_push_pull Multi-Way 8 17th October 2010 10:41 PM
Monacor SP200X help! Rabbit Full Range 7 2nd July 2009 10:07 PM
Monacor Vedo Multi-Way 2 10th February 2005 09:31 PM
Monacor SPH 130 AL - anyone? andyjevans Multi-Way 10 8th December 2004 01:43 AM
