Old 3rd September 2007, 10:32 AM   #1
Send a message via AIM to ConExp Send a message via MSN to ConExp Send a message via Yahoo to ConExp
Default Shouty 206es-r
I know this topic comes again and again but still to me the answer is not clear.
I have a pair of 206es-r installed in BiBs and I’m accumulating listening time with them.
One thing that bothers me is the some sort of screaming characteristic of these speakers.
Could someone help to clear this up?
Old 3rd September 2007, 11:33 AM   #2
hm is offline hm  Europe
hm's Avatar
Hello,
look the data below 800 Hz it needs
~5 dB +, and this is a measurement on a IEC norm baffle,
a 25-30 cm wide box is worth than that.
http://www.spectrumaudio.de/ (Fostextabelle)
Xmax only 0,6 there is compression near 0,5 watt ~70 Hz
Up to 800 Hz you can´t get a basshorn, only 200 Hz.
My solution would be
The small Schallmei sat and a sub,
or the SAXOPHON.
1 point is such drivers need a listening distance of more than 4m
then they sound good, in near field ~2 m most the time the
amp can´t reproduce normal levels, because only 0,05 watt is
needed, not every amp is fully there at 0,0...
http://www.hm-moreart.de
Old 5th September 2007, 10:15 PM   #3
Scottmoose's Avatar
While in principle I agree with Horst to an extent, I don't think its the lack of LF or lower mids that's your problem here. Looking at the ES-R data, even with the ludicrously heavily smoothed Fostex graph, the heavy peak at ~2.8KHz is very obvious, and I'd put money on it being more severe in practice than it appears on that mediocre plot. Even boosting LF sensitivity up to the driver's nominal by whatever method floats your boat, you're still going to have problems, because that peak is slap-bang in the region where our ears are most sensitive.
Two words: phase plugs. They'll take that peak right down, and smooth out the midrange & treble while allowing you to hear more detail, when before, you were just wincing. www.planet10-hifi.com
Old 16th September 2007, 11:02 AM   #4
Thank you both.
Scottmoose, do you have a simulation of the diaphragm excursion as a function of frequency for the design presented in Godsilla’s site?
My specific parameters are as follow:
L=387cm
Zdriver=83cm
Mouth area=908cm^2
Old 16th September 2007, 11:13 AM   #5
Scottmoose's Avatar
Not to hand. If I have time, I'll re-run the sim & check. Where will they be positioned? The mouth isn't a mouth; it's just a terminus; the room, and it's walls form the mouth you see.
206ES-R loud pop on startup tubesdude Multi-Way 1 13th August 2007 05:44 AM
BLH for the FE 206ES-R- Project Underway graykeene Full Range 19 5th July 2007 04:55 PM
Shouty FE167E in ML TQWT ghisdal Full Range 39 18th April 2007 10:14 PM
206es-r, Open Baffle style Pendergast Full Range 0 6th August 2006 02:04 AM
Page generated in 0.08201 seconds (73.39% PHP - 26.61% MySQL) with 10 queries
