DIY "speaker box" ("BOOM BOX"). Help needed.
Old 30th August 2007, 11:13 PM   #1
MASantos is offline MASantos  Portugal
Default DIY "speaker box" ("BOOM BOX"). Help needed.
Hello, I am looking to make a all-in-one-box design, similar in design and objectives to the ipod hifi.
This means a box with about 15-20 liters of volume(4-5 galons) with two full range speakers. I have been reading some threads here, and datasheets, and believe that a suitable driver size would be around 4" to 5". I have read good things about the fostex FE 106 and FE 126, and I also read good things about the tang band drivers but I could use some advice regarding the drivers.
The price should remain below 40/55$ per driver.
Power will come from a T-class digital amplifier such as those offered by 41hz.com autocostruire or diy paradize. The candidates so far are the AMP4, AMP6 , Class-T-Amp-2020-m-mk2 from autocostruire and Charlize.
Power will probably be a SLA battery but also a AC power using a transformer in a separate enclosure.
I need advice regarding the driver choice and size, enclosure tipe( bass reflex port or not, interior walls, and that kind of cabinet design issues.) Sugestions are very welcomed.
I have experience in woodworking for quite some years now, and a very complete woodshop at home with all sorts of tools. I have also experience in electronics but this would be my first speaker project.
Thanks in advance and start sneding those opinions!
Manuel
Old 30th August 2007, 11:25 PM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
FE106 is a mystery driver, did you mean FE103?
FE127 would be more suitable than FE126 (but in Europe these will likely exceed your budget)
A pair of Solo 103s (on Tony Gee's web site) would be suitable protos for the speakers.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st August 2007, 03:40 PM   #3
Yes, I meant the FE103's.
Do you have a link for this website?
Manuel
Old 31st August 2007, 06:46 PM   #4
Scottmoose is offline Scottmoose  United Kingdom
Scottmoose's Avatar
http://www.humblehomemadehifi.com/Solo103.html
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 31st August 2007, 09:04 PM   #5
frugal-phile(tm)
planet10's Avatar
Thanx Scott.
dave
Old 31st August 2007, 09:47 PM   #6
Saturnus is offline Saturnus  Denmark
Saturnus's Avatar
Though not quite what you seek, you can probably get a few ideas from the link in my sig to my boombox design. I'm currently testing low-cost tweeters that might sound better than those already in but so far my boombox has actually replaced my heavily modified Dali 404's as reference speakers. They are more natural and with greater detail and ambience feeling.
Old 2nd September 2007, 01:00 PM   #7
that boom box is exactly what I want, but half the size and with full range drivers. Apart from these differences your project is very cool!
in that link you provided I see that there is a cX-over for the drivers. Why do I need a X-over if this is a full renage driver? PLease pardon these questions but when it comes to speakers I'm still a bit of a noob.
Thanks in advance
DIY "speaker box" ("BOOM BOX"). Help needed.Hide this!Advertise here!
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
"boom box" AMP 12 Volt Magicdj Class D 28 17th February 2007 12:02 AM
Some final pics of "Stacks" revisited and "Askew" with stand Andy G Multi-Way 2 3rd February 2005 07:07 AM
"Forgiving" Speaker recommendations needed bigerik Multi-Way 0 30th November 2004 04:37 AM
Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? Ignite Multi-Way 3 18th November 2001 09:42 AM
