diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Full Range (http://www.diyaudio.com/forums/full-range/)
-   -   Help Needed for Norelco AD5200 12" (http://www.diyaudio.com/forums/full-range/107619-help-norelco-ad5200-12-quot.html)
Norelco 28th August 2007 12:29 PM
Presently im using my Norelco AD5200 in to my open baffles (Old Japanese design) i seen from JElabs. but now im planning to build cabinet. please advise on which existing designs i can use.. is it possible to use a horn loaded design? if possible pleeease send drawing..:D
Thank you very much in advance..
Regards:)
Simei 29th August 2007 03:47 PM
Hi Norelco,
I have a pair of Philips AD12202 similar to your Norelco AD5200. I fitted them in a Backloaded Horn Enclosure. They produce very good sound. Warm, smooth and rich bass. The enclosure is emulated JBL C34 design. The following is the enclosure design:
http://img337.imageshack.us/img337/8...2ins010jc3.jpghttp://img258.imageshack.us/img258/6...c34planlg2.jpg
Good luck!!! Cheers!!!:D :D :D
David
Norelco 31st August 2007 09:17 AM
Thanks for the advice;) , did you put add'l tweeter to support the hi frequency? sorry i cannot view the pictures you inserted to your reply.. what amplifier are you using? do you think is it ok to use into a ST70 Dynaco power amp?? if is ok to you to you to post the plan / drawing?:D
Thanks & Regards
Simei 1st September 2007 04:52 AM
Hi Norecol,
The Philips AD 12202 is quite easy to drive with most tube amps (300B, 6v6, EL84, Darling amp 1626 etc...). I do add a super tweeter to cover the high range as it roll off at 12,000hzs.
The amp in the photo is Consonance M99 plus, Rated at 20W. Very sweet and smooth sounding amp. Your Dynaco ST70 should have no problem with the AD5200.
You can see the enclosure plan at this link:
http://www.lansingheritage.org/html/jbl/plans/C34.htmhttp://img48.imageshack.us/img48/291...2ins013nz3.jpg
Good Luck!!! Cheers!!!
Norelco 1st September 2007 07:02 PM
Thank you very much simei.. ;), im so very excited to hear this speaker.. by the way.. did you put damping material inside???
More thanks again & regards..
Simei 2nd September 2007 01:54 AM
Hi Norelco,
I put rock-wool in the enclosure (as indicated in the attached picture) as damping material. It is advised that you don't put too much damping in the enclosure as it may make it sound dead.
It is also advisable to use 3/4" plywood to make the box.
http://img294.imageshack.us/img294/1...34planewg6.jpg
Good luck!!!:D :D :D
Simei 2nd September 2007 04:39 AM
Hi Norelco,
You may like to consider this vintage design @ the following link:
http://www.geocities.com/tadgesualdo...eTLDesign.html
Cheers!!!:D :D :D
Regards.
Norelco 2nd September 2007 10:18 AM
Thanks again for the info.. i think its much better to stick with jbl design, since jbl is well known in to their designs..:)
Regards..
noge 11th March 2014 11:10 PM
Can I revive this thread?
I have a few AD5200M drivers I've been wondering what to do with.
Has anyone tried these drivers in the JBL34 cabinets?:)
knarfor 12th March 2014 12:43 AM
I happen to have a 5200M sitting here at my desk. I just ran some measurements. Someone should be able to help you use them to figure out an appropriate enclosure:
Re=4.72 ohms
Fs= 43.07 Hz
Qts=0.533
Qes=0.571
Qms=7.975
Le=0.154
Mms= 32.96 grams
Vas = 183.1 Liters
On axis 1W/1M:
http://farm8.staticflickr.com/7432/1...5e3f4b5e_b.jpg
Resources saved on this page: MySQL 18.75%
Copyright ©1999-2017 diyAudio
