Old 27th August 2007, 04:15 AM   #1
sqlkev is offline sqlkev  United States
Default Hi-vi trinity 6 in a horn enclosure?
Anyone know if this driver will work in a horn box??
here are the specs
I just steal these on ebay
Old 27th August 2007, 08:25 AM   #2
Scottmoose's Avatar
You can use most drivers in a horn, assuming it's properly designed. But without knowing Vas (one of the most important driver parameters, which they haven't bothered including on the data sheet) sizing it accutately might be a problem -you'd have to over-size it, and damp it down if necessary
Old 27th August 2007, 09:37 AM   #3
here's some more info of the woofer from partsexpress
Woofer specifications: *Power handling: 40 watts RMS/80 watts max *VCdia: 3" *Znom: 4 ohms *Re: 3.2 ohms *Frequency range: 63-1,200 Hz *Fs: 63 Hz *SPL: 90 dB 2.83V/1m *Vas: .20 cu. ft. *Qms: 2.50 *Qes: .46 *Qts: .38 *Xmax: 2.7 mm.
Old 27th August 2007, 09:52 AM   #4
Scottmoose's Avatar
Yes, you can design a horn easily enough for that.
Old 28th August 2007, 03:25 AM   #5
is there any easy to use modeling program that I can play around with?
many thanks,
Old 28th August 2007, 04:02 PM   #6
many thanks,
Look into the BIB, there was a small discussion using that driver in a BIB, but was not going to fit the appplication after all. There are a few people still lurking around wanting to see the outcomes of a project using that driver.
BIB dimensions
hivi6
Fs 63.000
Vas 0.2
Qts 0.380
Line Length 106.861
Folded Height 53.431
Vb 1.193
Sm 38.596
Depth 7.388
Width 5.224
zdriver 23.189
a-b-c 3.694
Fliping Switches, Pushing Buttons, and Turning Knobs.
Old 9th September 2007, 09:51 PM   #7
BIB dimensions
hivi6
Fs 63.000
Vas 0.2
Qts 0.380
Line Length 106.861
Vb 1.193
Sm 38.596
Depth 7.388
Width 5.224
zdriver 23.189
a-b-c 3.694
Thank you for the info,
anywhere I can get some drawings of such BIB?
Old 9th September 2007, 09:54 PM   #8
frugal-phile(tm)
planet10's Avatar
http://www.zillaspeak.com/bib.asp
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 9th September 2007, 09:57 PM   #9
dave
thank you, Dave!
I'll build these in a couple of days and will report back.
Old 10th September 2007, 02:49 AM   #10
GM is offline GM  United States
GM's Avatar
Greets!
FYI, when I reverse calc BL using the published Cms I get a Sd that's considerably larger than the driver (~22.78" effective piston diameter Vs a 17.3 cm published overall dia.) and a BL best suited to compression horn loading, yet the 90 dB sens is about right with the PE specs, so not sure what's going on.
Calc'd based on Cms = 2.409 mm/N (published):
dia = ~22.78 cm/8.9685" ------ o.d. of driver is only 17.3 cm, so the rest are suspect!
Sd = ~407.55 cm^2
Mms = 265.3113 g
BL = 27
Anyway, scaled some dims off the PE picture:
effective outside dia. = ~13.1934 cm/5.1942"
effective inside dia. = ~7.252 cm/2.855"
calc'd:
Sd = 136.711 cm^2 - 41.305 cm^2 = 95.406 cm^2
BL = 6.3226 N/A
Cms = 4.3963E-04 mm/N
Mms = 14.5169 g
Sim of previously posted BIB: http://www.diyaudio.com/forums/attac...amp=1186116360
TC's BIB optimized for the T6:
L = 138"
zdriver = 30"
Sm = ~30.758"^2 (recommend ~4.687" W x 6.562" D)
a-b-c = ~3.281"
GM
File Type: gif hi-vi trinity 6 in t.c.'s bib - optimized.gif (8.1 KB, 209 views)
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Horn Enclosure for Fostex 206 Puffin Full Range 71 15th March 2009 09:25 PM
Trinity Tube Heads AriesMotor Vendor's Bazaar 0 14th November 2008 04:11 AM
HiVi Trinity 6 Arc Multi-Way 0 8th March 2007 03:27 PM
FE166es-r horn enclosure jeremyg Full Range 5 18th December 2005 04:22 PM
Convert horn enclosure to sub enclosure chipco3434 Subwoofers 5 22nd December 2004 03:54 PM
Page generated in 0.10033 seconds (80.87% PHP - 19.13% MySQL) with 11 queries
