Any more info in this design?
Old 26th August 2007, 12:54 AM   #1
wixy is offline wixy  Australia
Default Any more info in this design?
http://hb6.seikyou.ne.jp/home/makizou/
I'm interested in building the speaker below:
Does anyone have any info on this design? What driver is it? Where can I obtain plans?
Old 26th August 2007, 02:59 AM   #2
HWV is offline HWV  United States
Default M-8 Little bird
I had Google translate the text from the linked website:
8 centimeter new series appearance!! Play heart full load!
M-8 Little bird and M-8 [mitsushi]
Very popular MAKIZOU” M-8” new series appearance!
Play [gokoro] fully mini- swan type
It is appearance of the mini- resonance tube!!
It is interest fully miniature plan of small-sized 8 centimeter unit use.
Mini- mini- as for the empty interest of the original speaker was reconfirmed in good quality of the sounding [tsu] [pu] [ri] which cannot do either the imagination! It can enjoy sufficiently even with 8 centimeter unit of convenient price! If 8 centimeter unit you can use most ones. Exactly is in FE83 and FE87 etc of [huosutetsukusu].
M-8 Little bird
When as in the name, Little bird the hand is expanded largely, it is the palm size which rides one hand.
Completion size is height 170* width 170* depth 170mm of the body.
When you insert to the head, it is height 340mm.
It is 15mm thick plywood use.
2 lumber (in case of the Chinese plywood) with it is approximately 5Kg.
A certain clearing of Hari's the sound field impression it can enjoy the medium treble, well.
With the side view photo and the dimensions given, you should be able to reverse-engineer the enclosure.
Have fun!
-Hans
Any more info in this design?Hide this!Advertise here!
Hi, looking for some info on tube amplifier design basics rockgardenlove Tubes / Valves 5 22nd October 2008 01:57 AM
choke power supply design info? dorkus Tubes / Valves 3 21st November 2007 12:24 AM
Moray, whomever - anyone w. Karlson design experience to share info? freddi Multi-Way 0 11th March 2007 07:34 PM
Any design info on the Gilmore Raptor Digital Amp? LineSource Class D 21 8th September 2006 08:55 PM
Copyright ©1999-2017 diyAudio
