I am about to finish constructing the FE208Esigma cabinet for the FE206E driver.
I was planning on using some diy cat5e cable that I made up, with each cable consisting of two twisted pairs of cat5e (with the sheath still on) i.e. 4 x cat5e cables per speaker cable. I'm just wondering if this would work ok with the FE206E? |
#2 |
Well if it takes a signal from the amplifier to the driver, then yes, it will work.
Whether a wire works well with a speaker is actually dependant on the speaker / amplifier combination. Wire as wire per se doesn't have a sound (how could it?) but it's electrical parameters will affect the behaviour of the components it connects to each other. It should do fine, though to be certain, we'd need to know what your amp is. |
#3 |
Thanks Scottmoose. The amplifier is a Kingrex T20 (tripath amp), and occasionally an el34 single ended amp.
#4 |
The Cat5 should work decently with that.
#5 |
If you are going to use 2 pairs of CAT5, the best way to do it is to separate the individual wires and rewind them in a star pattern:
+ _ _ + Connect the +'s and the _'s at the ends. This give the best noise rejection. I'm not convinced that this is better than a single pair of CAT5 for a couple of meters run and less than 10 watts. Bob |
#6 | |
Just to fuel the never-ending "amp-wars" conversation, some of us might be more interested in your impressions of the 2 mentioned above Why do we like the things we do? Interesting if not required reading: http://www.yourbrainonmusic.com
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| cheap cat5e cable for speaker cable | fishline | Full Range | 6 | 19th May 2009 07:42 PM |
| problems with speaker cable as power cable | pjpoes | Parts | 11 | 14th January 2007 08:24 PM |
| 25 pair cat 5 cable for speaker cable? | mpmarino | Parts | 19 | 3rd March 2006 04:46 PM |
| Speaker cable | jaudio | Multi-Way | 3 | 6th October 2005 11:51 PM |
| electrical cable for DIY speaker cable? | leadbelly | Multi-Way | 7 | 13th January 2004 10:43 AM |
| Page generated in 1.84403 seconds (4.26% PHP - 95.74% MySQL) with 10 queries |
