Need help with BIB design
Old 20th August 2007, 11:14 PM   #1
jbloud47 is offline jbloud47  United States
Default Need help with BIB design
OK well im new here and really dont know that much about home audio, but i wanted to try to build BIB enclusure for two full range speakers that i have laying around the house. Question is how do i know how tall to make the enclosure and how big to make the throat of the enclosure? any imput is welcomed
Old 21st August 2007, 12:10 AM   #2
gmilitano is offline gmilitano  Canada
gmilitano's Avatar
That depends on what drivers you will be using.
Old 21st August 2007, 01:20 AM   #3
I just have two 4 inch full range speakers dont know any specs on them im just playing around with the idea to see what i can get them to sound like. I seemed like a fun project to mess with
Old 21st August 2007, 02:50 AM   #4
gychang is offline gychang  United States
look around here
http://www.zillaspeak.com/bib.asp
gychang
Old 21st August 2007, 02:52 AM   #5
GM is offline GM  United States
GM's Avatar
Greets!
Unfortunately, we're not wizards, so with no driver info beyond them being 4", about all I can say is build T.C.'s BIB and experiment with stuffing up in the pointed end, around the driver, and down on its 'floor' until you get the best sound and it is what it is.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 21st August 2007, 04:18 PM   #6
thanks for the info like i said i didnt know the formulas to how these type boxes are designed that thats why i ask
But i have narrowed my sellection down I think im going to pic up a pair of 4.5" pioneers or a pair of Tangband 4" 1052SA. Im looking for them to be as loud as possible since they will be for sound in my garage and i would like them do get as low.
pioneer spacs.
Power handling: 20 watts RMS/30 watts max * Voice coil diameter: 1" * Impedance: 8 ohms * Frequency response: 70-15,000 Hz * Magnet weight: 9.3 oz. * Fs: 70 Hz * SPL: 90 dB 1W/1m * Vas: .31 cu. ft. * Xmax: 1.1mm * Qms: 1.40 * Qes: .47 * Qts: .35 * Net weight: 2 lbs. * Manufacturer model number: A11EC80-02F * Dimensions: Overall Diameter: 4-1/2", Cutout Diameter: 4-1/8", Mounting Depth: 2-3/8", Magnet Diameter: 3-1/8", Magnet Height: 1".
TangBand:
Specifications: Power Handling: 45 watts RMS/90 watts max *VCdia: 1" *Znom: 4 ohms *Re: 3.80 ohms *Frequency range: 60-15,000 Hz *Fs: 63 Hz *SPL: 90 dB 2.83V/1m *Vas: .26 cu. ft. *Qms: 4.52 *Qes: .49 *Qts: .44 *Xmax: 4 mm *Dimensions: Overall Diameter: 4-9/16", Cutout Diameter: 3-3/4", Mounting Depth: 2-1/4".
Old 21st August 2007, 09:35 PM   #7
brucedal1 is offline brucedal1  United States
Send a message via Yahoo to brucedal1
http://www.zillaspeak.com/BIB-Tangband.asp
I built one with the 1052SA and I liked it a lot. The tweeter helped though
Old 22nd August 2007, 05:04 AM   #8
thats the design i was thinkign of going with and adding a piezo tweet but i just dont know about the placement and what kind of cap or resistor to use and how to wire it in.
Old 22nd August 2007, 04:32 PM   #9
Godzilla is offline Godzilla  United States
Godzilla's Avatar
http://www.zillaspeak.com/Bamboo.asp
You can try it on the back like the above.
- Piezo on back connected to .33 uf capacitor + 20 ohm resistor across. -
Godzilla
Old 22nd August 2007, 08:38 PM   #10
GM's Avatar
Greets!
You're welcome, but I sure didn't get this from your earlier posts. Anyway, here's what I came up with to allow anyone to 'roll their own': http://www.diyaudio.com/forums/showt...24#post1229324
GM
Need help with BIB designHide this!Advertise here!
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
4th order bandpass, wheel well design :) (design inside) TWOJZ Car Audio 28 13th January 2008 02:56 PM
