Old 20th August 2007, 01:29 PM   #1
Default JX92s Maclementhorn
Hi
I did quick search and didn't find posts about this front loaded horn.
http://www.maclementhorn.it/TqwtHorn.htm
Have always thought that jx92s is not suitable for front loaded horns.
Any comments or opinions?
xxx I should correct my spelling xxx
Old 20th August 2007, 02:11 PM   #2
GM is offline GM  United States
GM's Avatar
Greets!
That's what its designer says. It's my understanding that BLHs are out too, though a big vent reflex (BVR) style should be OK.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th August 2007, 06:11 PM   #3
Hmm, Horst Moller has one BLH also.
http://www.hm-moreart.de/17.htm
Old 20th August 2007, 07:29 PM   #4
GM's Avatar
J-Low (scroll down): http://www.passdiy.com/speakers.htm
Old 20th August 2007, 09:32 PM   #5
GM
Why shouldn't these Jordan fit a horn? In my ignorance and lack of knowledge can't see any reason why not.
Anyway, time for some eye-shut.
Cheers!
Old 21st August 2007, 11:39 AM   #6
Colin is offline Colin  United Kingdom
Jordan drivers have been used in horns in the past. The smaller, JX53 drivers have been used in front horns - there was a designer in Wales some years ago who built custom horn installations using them.
The website has a design which uses both the 92 and 53 in a compact enclosure.
Old 21st August 2007, 12:33 PM   #7
Someone in the Oris horn foorum mentioned,"Horn can be used as a waveguide",and that Maclementhorn has done it this way.
So does the waveguide mean that the horn is not really used for amplifying certain frequencies,only directing them?
Old 21st August 2007, 05:41 PM   #8
t-head is offline t-head  United States
Default JX92S in TL
FWIW, I have the drivers in a Transmission Line built by Carolina Audio. I imagine it is a modification of a design on Jordans site. They are very suited to 1/4 wave folded and tapered TLs.
Tea
trust, but verify...
Old 22nd August 2007, 08:51 PM   #9
GM's Avatar
Originally posted by peterbrorsson
GM
Cheers!
Greets!
I assume it's due to the suspension design and what appears to be a rather fragile diaphragm design not being able to take much compression loading before it either damages itself when pushed hard and/or audibly alters its response for the worse, but mostly because its designer says it's not recommended.
Really, TJ ought to join the various forums and chime in on threads concerning his products. (hint, hint, Colin)
GM
Old 22nd August 2007, 08:55 PM   #10
GM's Avatar
Greets!
Right, a WG only increases the driver's directivity, not actually compression load it, so this is what I recommend to act as an acoustic BSC.
GM
JX92S On SALE! mdikovics Full Range 40 13th July 2008 03:42 PM
BIB for JX92S ? britbug Full Range 22 26th February 2008 07:10 AM
Jx92s VTL Russ White Full Range 6 15th March 2006 05:07 PM
Lvc for JX92S Dave Jones Full Range 2 19th August 2003 04:23 AM
Page generated in 1.50240 seconds (7.60% PHP - 92.40% MySQL) with 10 queries
