Well, I had planned to build MK’s TQWT later this year but … as we are having a Brisbane Builders Met at my place on the 2 Sept and I have a few fee days available that week though I might build them for the met (hey, that’s risky building to a deadline!.
These are only trial boxes so I’m building out of “seconds” 17mm ply which no doubt has voids. So though I’d add bracing for more rigidity – see drawing (dims in inches) below. No science to this but assume tapered front/backs wouldn’t need much so put most on side-side. Any comments?? I couldn’t spot the positioning of the port on Martins drawing so have placed it 4” off the base Cheers - Phil PS - typical just spotted dim error - top measurement in 2.5" not 1" |
#2 |
Should have modified sketch earlier but Doug [Brisso57] came to help me veneer the Small Thors - lookin good.
Just in case someone takes my sketch seriously (ha) this is now correct top should be 2.5" as per MK, which effected some of my interior dims. |
#3 |
frugal-phile(tm)
Looks like totoally adequate over-kill
Just make sure the side-to-side braces are off-centre dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Looks good. The more bracing the better IMO.
#5 |
Dave – I assumed that as MK hadn’t included any bracing. As this is only a hobby and time isn’t an issue and the bracing is cheap – overkill is good.
Scott is my placement of the port correct – 4” off the base?? Cheers - Phil |
#6 |
frugal-phile(tm)
BTW this link gives some alternate ways to shape an ML-V (Milevea adds another way of folding one too)
http://www.t-linespeakers.org/FALL/bipolar/index.html dave
#7 |
Thanks for the link Dave, had looked at them ages ago and forgotten them. I actually like Martins lob sided design.
I’ve thought about bi-polars a couple of times but I like as much open space in my living room as possible so my speakers are always close(ish) to the wall. I’m assuming with bi-polars you’d need a good about of space between the speakers and the rear wall. That why I also like forward firing ports. Cheers - Phil |
| SPL from additional drivers | 454Casull | Multi-Way | 0 | 8th April 2009 01:36 AM |
| Using a 2-Way System w/ Additional Woofer | TubeHead Johnny | Multi-Way | 5 | 13th December 2007 04:25 PM |
| Additional hardware os with multiple os filters ? | Bernhard | Digital Source | 0 | 21st January 2005 08:07 PM |
| Bracing a straight (unfolded) ML-TQWT? | joensd | Multi-Way | 10 | 16th April 2004 01:37 AM |
| Suggestions On Additional Circuits | jaramke | Solid State | 0 | 6th February 2004 09:33 AM |
| Page generated in 0.08988 seconds (76.59% PHP - 23.41% MySQL) with 11 queries |
