Old 16th August 2007, 09:02 AM   #1
Default F200A in spherical steel infinite baffle enclosure
I am getting to the end of a loudspeaker project using Fostex F200A drivers in spun spherical steel enclosures.
The spheres are about 510mm outer diameter to give about 70 litres of volume (after damping). The wall thickness is 3mm. Modeling the F200A in a sealed box of this volume gives an -3dB point of 74Hz.
So far, the sound has improved as I have added more and more stuffing to the enclosures.
The sound of these speakers is awesome. I've used other Fostex 8" full-rangers before but the F200A has so much more body and depth. It is a great unit for infinite baffle enclosures.
Can anyone offer any advice on the best method of damping the insides of a spherical enclosure? I understand that there will be one main resonance, caused by the consistent diameter of the sphere.
Old 16th August 2007, 09:04 AM   #2
another pic showing the speaker, gainclone amp and DEQ2496
Old 16th August 2007, 09:11 AM   #3
OzMikeH is offline OzMikeH  Australia
Default Re: F200A in spherical steel infinite baffle enclosure
remember the driver is not in the centre of a sphere. so there is no one consistent distance from the driver. you have the next best thing to an open baffle.
Awesome enclosures. the eyes follow you around the room..
Google the words Elliot sound and westhost then look at the baffle step article.
Old 16th August 2007, 01:08 PM   #4
They are avesome!! BTW, stands also
Peter
Old 16th August 2007, 02:31 PM   #5
Thanks - I had a metal spinner build them to spec.
The two halves of each sphere are spun from flat sheets of steel, then welded together with an additional steel strip on the inside. A flat section cut to match the F200A was welded on to each sphere.
There is also a steel bar running from side to side inside the sphere, to reduce ringing.
As the metal is spun, the thickness of the walls varies slightly. It is thickest around the driver (and at the rear opposite) and thinner towards the middle. This is a nice side-effect of the spinning process that also reduces ringing.
I'll get better photos next week....
Old 16th August 2007, 05:13 PM   #6
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
It would seem that the sticky goos that car audio people use might be good. After all , they were made to damp sheetmetal. There have been products mentioned here, some roofing compounds for example, but I need to try and find them. You want something that will remain a bit flexible I believe. Easy to apply- remove driver, pour in goo, cover and rotate! Steel really does ring, so attention to this should pay off big!
I very much like your idea.
Old 17th August 2007, 06:21 AM   #7
frugal-phile(tm)
planet10's Avatar
Those are quite special
The stands do need some work...
A wad of fairly dense damping should be placed right at the centre of the sphere.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd September 2007, 10:23 AM   #8
Well these speakers are almost finished and are installed at the new BBC Scotland headquarters. All that remains is for a custom aluminium ring to be installed over the driver to hide the octagonal basket.
The huge bell shaped external frame is designed to create an audio immersion zone with little spillage outside. The HF beaming of the 8" full range driver was advantageous in this instance!
There are two of these 'sound cones' - both have a DEQ2496 upstream.
Not exactly hifi and not exactly DIY, but this forum has been a great resource for me on this project.
Old 3rd September 2007, 10:26 AM   #9
view of a sound cone from the outside - 3m high and 3m wide.
Old 3rd September 2007, 10:38 AM   #10
Pano is offline Pano  United States
Pano's Avatar
Wow! That's um... Wow!
Are you sure it's not a rocket engine?
Take the Speaker Voltage Test!
Infinite baffle vs Sealed enclosure IG81 Full Range 2 4th March 2009 02:47 PM
spherical enclosure MrSensitive Subwoofers 94 6th March 2006 07:06 AM
help w/ infinite baffle sub HIPCHECK Subwoofers 5 16th December 2005 12:19 AM
Infinite Baffle. Best bet if possible? Hybrid fourdoor Multi-Way 50 9th July 2004 08:52 PM
Materials For Spherical Enclosure Ignite Multi-Way 15 12th December 2001 08:15 AM
Page generated in 0.11496 seconds (82.83% PHP - 17.17% MySQL) with 11 queries
