i have these Dual speakers which are for car audio systems but i want to use them in my home. I wired up a car audio amplifier i just need help in building an enclosure for these speakers. I contacted the company for other specs but they were unable to give me the sufficient information.
Speaker size: 6.5 inches
* Design: 3-way
* Cone material: Brushed metalized silver polypropylene cone
* Tweeters: 25mm midrange, 15mm tweeter
* Power handling, RMS: 50 watts
* Power handling, peak: 140 watts
* Frequency response: 50 Hz - 20 kHz
* Impedance: 4 ohms
* Grille material: ABS framed metal mesh grill
* Mounting depth: 2.86 inches
* Cutout diameter: 5.64 inches
Looking forward to your help
mark
* Design: 3-way
* Impedance: 4 ohms
mark
ahhhhh sorry it took a while for TL to sink in.... Do you seriously think that would work better than a baffle? How would you go about designing a TL? The only sucky part about the drivers i want to use is that there are no parameters to go by.... is there a way around this?
i would just sit down with a calculator and do it also but to my knowledge there are many different ways to build an open baffle and with every little variation the type of sound produced. I would use the program that martian has but the parameters needed aren't avaliable even through the company. thats the only pit fall so i was hoping there was a way around this
- Full Range
- Enclosure design
