Old 8th August 2007, 10:58 AM   #1
stevenc is offline stevenc  Malaysia
Default Damping For Fe103 Fostex Recommended Horn
I have built the fostex recommended box for the fe103e. I need some help with the following.
1. the recommended box does not have any suggestion for damping/lining/filing. Should there be any?
2. How CRITICAL is the horn size. I could not find 15mm ply and have therefore used 18mm instead and have made adjustments but I am afraid it may not be perfect (the unprofessional capentry also contributed).
Your suggestions will be greatly appreciated.
Thanks,
Steven Chan
Old 8th August 2007, 11:21 AM   #2
marce is offline marce  United Kingdom
Hi Steven
I recently completed some Fostex FE166 BLH, there is a thread on here about my experiences, and an awful lot of good advice as I was in the same boat as you. I would have a read of that thread and a couple of others that will answer a lot of questions.
I made the mistake of lining the back of the expansion chamber with acoustic foam and damping material, and it totaly killed the sound of the speakers, no bass.
On advice I ripped it all out and everything came to life.
I'm running my FE166's now with only some "craft foam" lining the mouth of the horn (for apearance) and no other lining or stuffing and they sound wonderful.
The great thing is building something that sound good, trouble is it dose become addictive.
Fostex recommended FE103 Enclosure Rega Full Range 27 12th January 2008 06:59 AM
Anone have experience with this fostex FE103 design? gnugear Full Range 11 5th October 2007 06:41 AM
Damping enclosure for FE206ESR recommended horn no xo Full Range 6 13th April 2006 07:24 PM
best enclosure for fostex fe103 jesserparker Multi-Way 10 3rd August 2005 04:05 AM
Fostex Fe103 combined with woofer. jim Multi-Way 25 21st August 2004 06:53 AM
Page generated in 0.07005 seconds (68.98% PHP - 31.02% MySQL) with 10 queries
