Old 7th August 2007, 07:25 AM   #1
Default need some help to choose my first horn
Im new in here and my english is poor but i i'll try!
I looking for my first diy sound project and im dont know what i do!
I've search on internet and i like these two projects:
FE87E + Recomend enclosure [or an makizou]
http://www.madisound.com/pdf/fostexdrivers/fe87erev.pdf
and
vifa kit + Recomend enclosure
http://www.madisound.com/pdf/Swifty.pdf
what project give me an better sound?
anyone have an better project?
i will use these speakers on my office [12m2]
[i want spend max $100 on a pair of speakers]
Thank you and cheers!
Fran
Old 7th August 2007, 07:51 AM   #2
Scottmoose's Avatar
The 87 & its horn cabinet are rather nice. Very little bass, as you'd expect (it's only a 2in cone after all) but the rest is excellent.
Old 7th August 2007, 07:53 AM   #3
OzMikeH is offline OzMikeH  Australia
The FE87 cabinet you show should be put on the floor to work best. I have not heard it before.
Do you want to put these speakers on the desk or on the floor in your office?
Do you want easy wood work or are you happy to do complicated and difficult wood work?
You might like the Zigmahornet with an FE103 if you want the speakers to stand on the floor. It is a little bit more expensive than the FE87 but the cabinets are easier to make and take very little space.
Old 7th August 2007, 05:22 PM   #4
Send a message via ICQ to Crossblade Send a message via AIM to Crossblade Send a message via MSN to Crossblade Send a message via Yahoo to Crossblade
FE126e - Frugel Horns
Old 7th August 2007, 09:12 PM   #5
First, tanks for the help!
OzMikeH, i want put the cabinet on the floor and i lovet the zigmahornet
And i like complicated wood work and now im considering a double horn [mikasa or harvey] whit fe126e. and now, the zigma!
i need do an choice now...
What horn works well??
zigma + fe103
An Ron's double horn + fe 126e
And sorry Crossblade...i dont like the frugel design!
thanks anyway!
cheers
Old 7th August 2007, 11:06 PM   #6
no..i dont want a double horn!
iv decided build a litle one!
after reading lots of stuffs, let me ask one thing:
i listen all kind of musics like jazz, blues, classic rock and indie rock...so what horn fits to me?
After reading some text on internet, i think the zigmahorns + fe103 fits well!
Im correct?
tnx and cheers
Old 8th August 2007, 12:55 AM   #7
schetl is offline schetl  Hungary
schetl's Avatar
PepperHorn
An ultralow budget and amazing
Old 8th August 2007, 02:19 AM   #8
schetl, the project look great but i have tree problems!
1 - i dont understand the linguage on the web site
2 - i need at least one review to know how the work [i didn found in english]
3 - The speakers to use on them...
if you explain better, will be very helpfull for me!!!
Old 8th August 2007, 05:20 PM   #9
schetl's Avatar
Ok. Hungarian is not so simple language
This is a new project. You can't find english review yet.
Drivers: HiVi B3s. These are emphatically lucky construction. It has 3 mm Xmax and very balanced midrange. Due to relatively low sensitivity it performs amazingly strong in an optimal quasi-conical horn. No needs electrical compensation.
Pepperhorn works with some other 3" drivers (e.g. Visaton frs8) but the optimal is B3S. Material: MDF 12 mm (0.5"). To achieve the lowest distortion important the conical cutout (expanding backwards).
Cutoff around 50 Hz, depending the placement. Nominal impedance 4 Ohms (due to drivers are parallel). SPL (1w, 1m): 85 dB.
http://www.aq1.hu/pepperhorn.pdf
Old 8th August 2007, 10:41 PM   #10
Nanook is offline Nanook  Canada
Nanook's Avatar
Default franskaf....first horn
ok, one of the projects isn't a horn.
Also, what amplifier? what size room?
your budget is tight but with the BN3 drivers, pretty easy to do, but what about shipping? What is available in Brasil? Or would you order from US? What about Visaton? or something that may be available on your continent unless import taxes on some things are high.
Also, the Frugal Horn is pretty amazing. What don't you like about it? cosmetics?
stew -"A sane man in an insane world appears insane."
Horn experts - Please help to determine optimal throat size for low-mid horn pk Multi-Way 7 21st March 2010 05:31 PM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
How to choose the correct Horn?? Jer Multi-Way 12 14th November 2003 06:37 AM
Page generated in 0.09451 seconds (84.23% PHP - 15.77% MySQL) with 11 queries
