Hello
What think of this association? TangBand W4-657B and BaasExciter BX10. I think of ordering them here: http://www.lautsprechershop.de/francais/index_hifi.htm I would like to make two satelites and a box of low register. Which volume advise me? Thank you |
#2 |
Nobody little to help me??
#3 |
The TangBand W4-657 is not very usable as a fullrange. It definitely needs some notch-filters, or even a separate tweeter. The 3" W3-315 and W3-871 work much better as fullranges and can do without notch-filters.
For sub I have no experience of the BassExciter, no idea how it performs. One other option would be a TangBand W6-1139. It's smaller, but works very well in a small 2.1 system. What kind of amps are you going to use with the system? |
#4 |
This system will not be for a computer but for a system home-cinema. I will want to obtain something like system BOSE.
My living room made 35m² thus a 25cm will have to suffir for the low register. Here the place where the system will be instaled: ![]() Bose cuts to 10Khz these satelites and the sound is appropriate to me very well. With will your opinion in which volume I have to charge them, in field or bass-reflex ? Thanks. |
#5 |
This one could be interesting if you want a well performing but small speaker for HT:
http://www.zaphaudio.com/audio-speaker20a.html It's not a fullrange design, but it's not really that difficult to build. |
#6 |
I made sattelite speakers for my home cinema using Visaton FRS8 drivers in small (1L) sealed enclosure. These have worked out really well and I would recommend them, or possibly the newer Visaton FRS8M which seems to have a similar frequency response but with a larger magnet and higher efficiency. |
#7 |
Thanks you for this link
Indeed construction seems simple to realize but the volume of load will be appropriate it for my TangBand Does the WinISD software give me 3L volume of load out of bass-reflex, when think? |
#8 |
The amplification of the satelites this will make with a TDA7293 and the box of low register with a LM3886.
#9 |
What think of the litrage that WinISD gives me?
| What's your system looking like right now? | jduffy | Chip Amps | 1 | 5th May 2008 08:38 AM |
| Dj System | GOWA | Multi-Way | 5 | 6th July 2007 03:57 PM |
| Switch realization for this idea | rtarbell | Parts | 4 | 7th March 2007 03:14 PM |
| PIC Of My system in the car | Dj BASS AMP | Car Audio | 10 | 10th January 2004 10:38 AM |
| Your First System | nobody special | Everything Else | 14 | 13th December 2002 02:19 PM |
| Page generated in 0.13889 seconds (60.52% PHP - 39.48% MySQL) with 10 queries |
