Old 3rd August 2007, 09:03 AM   #1
Default Room size for FE206E
The size of my sitting-room and dining room together is around 250 square feet. The area of my sitting-room, where my Hi-Fi is put, is around 120 square feet. Should I choose BLH FE206E or other full range driver.
Sleephead04
Old 3rd August 2007, 09:09 AM   #2
Scottmoose's Avatar
The 206 should be fine.
Old 5th August 2007, 08:18 AM   #3
are those measurements correct?
120 square feet? that is 10 by 12. not that a small living room is bad, but the large fostex stuff just don't go well with a small room IMO.
eh... I might go with a smaller driver. bass will propogate sooner.
got pictures of your room? construction style is important too.
Clark
Old 5th August 2007, 02:44 PM   #4
Scottmoose's Avatar
I used to go that way too, until GM pointed out that it just gives more tuning flexibility. Now I tend to go for the larger drivers -works for me anyway, and being a rocker at heart I they suit me better. Now I've said that, you can squeeze a heck of a lot of sound out of the 6 1/2in & 4 1/2in drivers & they generally have better mids & highs.
Old 5th August 2007, 03:23 PM   #5
MJK is offline MJK  United States
Why? I don't see any reason why an 8" Fostex won't work well in his room.
How does bass propagate sooner?
Old 5th August 2007, 04:19 PM   #6
hm is offline hm  Europe
hm's Avatar
Hello,
i´ve heard my SAXOPHON in only 16 sqm, it works.
More important, clap your hands, if the sound
comes later out of the dining room, you need a
curtain between or a large wall carpet ~4 cm before the wall
in the dining room to reduce the echo.
http://www.hm-moreart.de
Old 5th August 2007, 04:46 PM   #7
Scottmoose's Avatar
& I've run MLTLs with 8in Fostex drivers in even smaller spaces. Ed has similar space for his Vofo TQWTs which have the 206 and they work fine.
Shoe-horning a big BLH with the 206 into a very small room is going to need some tweaking to get going right, but it'd be fun.
Old 6th August 2007, 02:57 PM   #8
Puffin is offline Puffin  United Kingdom
I run the 206E in a 208 BLH cab in a room 10x10. Magical bliss !!
Old 11th August 2007, 01:08 PM   #9
wixy is offline wixy  Australia
I've got a choice between rooms for my FE206E's in FE208ESigma cabinets, as indicated in this diagram: http://img54.imageshack.us/img54/287...optionsbh7.jpg
Which option would be better?
Old 11th August 2007, 05:33 PM   #10
I would think option B. I would suspect you may find that If you use option A the opening on the left hand side could cause imaging problems.
Room size and ES hybrids? Alabama978 Planars & Exotics 1 2nd September 2008 09:45 PM
Room size considerations? ryoung Everything Else 0 28th March 2008 01:06 AM
Help, Foxtex Fe207E FE206E hole size OzMikeH Full Range 5 6th April 2007 10:51 AM
Speaker size v Room size cliffy Multi-Way 6 19th February 2005 08:34 AM
Page generated in 0.15916 seconds (52.23% PHP - 47.77% MySQL) with 10 queries
