Hey all!
So I still haven't finished my frugelhorns, but I have the drivers in the fostex recommended BR boxes. They're well broken in now, been doing primary speaker duty in my house for months now. The 126's are fantastic for music and vocals, but for movies and TV it's really lacking sizzle. (I have good high freq hearing.) I need a tweeter. Any suggestions that match well and won't break the bank? I found one person saying that the Fountek NeoCD3 ribbons match really well with the Fe126e's, but they go for $90 each. I'd like to keep it under $100 for the pair of tweeters, preferably well under $100. |
#2 |
perspective is everything |
#3 |
why not keep it in the family?
if domes are to your liking (might be a bit dark to match with the 126 though) http://www.madisound.com/pdf/fostexdrivers/ft207d.pdf the little horn is even cheaper, if your 126s's aren't already causing and issue with a CRT video display, adding these might be a tipping point - it would also likely need some attenuation http://www.madisound.com/pdf/fostexdrivers/ft17h.pdf
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#4 |
I'm tempted to go with ribbons for their superior off-axis response.
The fostex super-tweet seems quite nice, and would probably pair well, but it's super directional as well. |
#5 | |
Fair enough, the HiVi specs at P-E's page don't show dispersion past 30dg off axis, but they otherwise look like they could suit the intended application and budget. IINM, this looks similar to a ribbon that Steve Deckert uses in his current product line - with rave reviews from all who've heard or purchased them. Have you decided yet about a supra baffle for the FH?
#6 | |
The speakers are pretty much flanking the TV, so the inside edges won't have supra-baffle, but they will have TV baffle. I'm debating working it into the lines on the outer edges, assuming it has sufficient WAF.
#7 | |
never safe to assume that - sometimes you just need to ask. The most well tolerated speaker I've yet made for my wife just got sold on the weekend, but I can always build another.
#8 | |
Vertical dispersion is nearly non existent with this driver.. but horizontal dispersion is excellent (and likely superb for any driver at any axis). It isn't a true ribbon - and it won't sound as good as one, BUT it likely will sound better than any normal tweeter. Moreover with a crossover above 4 kHz and not to much power input - it should handle a simple first order electrical well (which a true ribbon would not). Then of course there is the price - you aren't going to beat this driver for efficiency and usability in a non-standard tweeter. Moreover, Madisound sells them for more than 10 bucks more - each. Bottom-line: Its the best tweeter for klocwerk's application I can think of at a price he can "stomach". Here is the application with the reinforced true ribbon (and the reinforced version doesn't sound as good as the normal pleated type): http://www.troelsgravesen.dk/FE126E.htm Note that there is a cheaper version of the Fountek - but *I* think its less ideal (in several respects), and it costs quite a bit more: http://www.madisound.com/catalog/pro...oducts_id=8190
#9 |
Don't let narrow dispersion put you off too much. I was thinking that way and considering the Fostex ring radiator tweeter. Then I learned how much early high frequency reflections mess up imaging. Many people do love their ribbons but will they be enough from a standing position?
The FT17H is good for me (except it's ugly) because I like good imaging and I only sit in the right spot when I listen carefully, If I'm not doing that then I just want something that is fair when walking around the room. If you have a whole family sitting down watching movies the ribbons are for you. |
#10 |
I'm worried about horiz. dispersion because we have movie nights occasionally with friends, and due to the layout of the living room people sit in nearly 120 degrees of arc around the TV.
No one stands to watch though, that'd just be weird. |
| BIB for FE126E | blasko | Full Range | 2 | 31st August 2007 04:23 PM |
| Help!---which t-nut is for FE126E | pwan | Full Range | 7 | 11th August 2007 03:34 PM |
| Yet another Fe126e mod! | dfreemansc | Full Range | 46 | 29th January 2007 03:54 AM |
| Here is what I did with my FE126e's | audiophile36 | Full Range | 6 | 27th October 2006 03:16 PM |
| WTB : Fostex FE126E | Cacophonix | Swap Meet | 0 | 27th February 2006 03:52 PM |
| Page generated in 0.16112 seconds (66.92% PHP - 33.08% MySQL) with 10 queries |
