Old 29th July 2007, 10:14 PM   #1
Default Debugging a B3S Zaph clone
I'm trying to build an instance of Zaph's design with the B3S he described there:
http://www.zaphaudio.com/smalltest/compare.html
This is what they look like:
I would grateful if you could help me debug them.
I am getting a 12 decibel boost around 7000 hertz. According to Zaph's description, I should be getting a 4 decibel boost there as a result of the breakup mode of the aluminum cone, not 10. So I am wondering if I am seeing some other effect. My boost is also much wider than his.
I am measuring from an apartment room. It is a pretty bad environment to be measuring in. I am trying to compensate by taking a variety of near field measurements. In the graph below, the thin colored lines are the individual measurements. Yellow is at 10 cm, blue is at 20 cm, orange is at 40 cm. There are two blue lines and to orange lines because it took to measurements from slightly different positions. The thick white line is the average of all the measurements. The thick purple line is the response curve Zaph shows on his web site.
This is with the crossover Zaph proposes in his article. This is measuring with an unmodified Radio Shack dB meter. They are not stuffed, and not damped/
Do you have any idea what this could be? What would be the best way to try to fix it? Thanks.
Old 30th July 2007, 11:48 AM   #2
Cool speakers. Very.
I just built Zaph's HiVi B3s speakers... thanks a lot, Zaph! :) fjhuerta Multi-Way 21 23rd May 2011 10:46 PM
Speaker idea based on Zaph ZD5, thoughts please, Zaph? wigginjs Multi-Way 23 3rd April 2009 05:09 AM
Zaph ZRT -vs- ProAc 2.5 clone jallenbass Multi-Way 4 23rd August 2008 02:15 AM
Debugging my Aikido Bas Horneman Tubes / Valves 38 1st August 2005 10:25 PM
Page generated in 0.10143 seconds (57.47% PHP - 42.53% MySQL) with 10 queries
