Old 29th July 2007, 04:01 PM   #1
fin1bxn is offline fin1bxn  United States
Default Next project - TQWT for EV SP12b
Since my Karlson pipe cabinet for these sucked (no bass bellow 150,but had great imaging and eff), I want to build a TQWT. I used the calculator to deturmin dimentions and need tips for dampling / stuffing. I'm going to use 3/4 birch, unless someone thinks MDF is better.
Any tips?
Bob
RN
Old 29th July 2007, 04:05 PM   #2
Scottmoose's Avatar
Which calculator? If it's the Rutter excel sheet based on Weems's articles, you might want to hang fire as you won't get an optimised enclosure out of it. Birch ply is the stuff to use, unless you're feeling in a luxurious mood & can afford apple ply.
Old 29th July 2007, 04:09 PM   #3
Default it was the rutter
Here are the driver spec's
Re=6.7
Sd=535 cm2
Bl=8.76 N/A
Vas=167 liters
Cms=411 uM/N
Fs=45
Qms=5.9
Qes=0.75
Qts=0.665
Pe=65Watts
Xmax=3.3 mm
Eff=94.96 dB
Dimentions given were 45" high 14" wide 19" deep with a 34" inch from 7" bottom opening 3/4" in
I welcome any other cabinet specs
RN
Old 29th July 2007, 09:36 PM   #4
Scottmoose's Avatar
The driver specs don't really suit a resonant cabinet IMO -Q & Vas are too high. Unfortunately my main PC is currently out of comission while some building work is going on in the house so I can't access most of my software properly. FWIW though, I suspect a sealed or aperiodic box is probably the best bet for these untis without going to a very large box. Attached is a rough sim. of the response you can expect from the aforementioned TQWT though.
Old 4th August 2007, 01:24 PM   #5
Default I'm ready to start cutting Wood -Sugestions
I'm going to go with the folded horn made from 3/4" birch, unless someone has a better cabinet design for these....Help is requested.
Bob
RN
Old 4th August 2007, 01:27 PM   #6
Scottmoose's Avatar
Which folded horn?
Old 4th August 2007, 03:36 PM   #7
Default one of these
Here is the link to the type
http://melhuish.org/audio/DIYTQ3.html
RN
Old 4th August 2007, 04:47 PM   #8
GM is offline GM  United States
GM's Avatar
I calc'd a BIB, but at ~71.5 ft^3, I guess it's not a contender........
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 4th August 2007, 04:52 PM   #9
GM's Avatar
Hmm, even a simple max flat impedance TL weighs in at a hefty ~13 ft^3.........
Old 4th August 2007, 06:05 PM   #10
Default I just ran WinIS
Maybe people are right and I should do a Open baffle.
Seems they need room to breath.
Using the WINIS software i came up with a 24^box 37 wide 58 high and 22 deep and that vented, Sealed is even bigger...BUt they show great flat response down to 30hz
I wonder what they made these drivers for. I know with the Corner Carlso cabinets they imaged and had gret midrange, just no bass.....Maybe I should also try a regular Karlson cab
RN
MK’s ML TQWT project greenie512 Full Range 4 13th May 2007 10:56 PM
Need best Cabinet for EV SP12B fin1bxn Multi-Way 0 26th January 2007 11:49 AM
New Project Beta 12LTA Fostex FT17H in a TQWT MIKET Multi-Way 27 23rd March 2004 04:14 PM
my first ml tqwt Tomac Multi-Way 15 13th March 2004 03:06 PM
New ML TQWT project tda Multi-Way 18 21st December 2003 01:50 AM
Page generated in 0.15860 seconds (58.24% PHP - 41.76% MySQL) with 11 queries
