Old 22nd July 2007, 02:32 PM   #1
slhijb is offline slhijb  United States
Default Tear in Driver Rubber Surround
Damn! ruined my day. My screw driver slipped and put a small 1/4" tear in the rubber surround of a new Scan Speak 18W-8545-00 driver. The driver is going into an 18 liter vented cabinet. I've gone through the archives and read the repair posts, but hoping for comments from experienced folks on the best repair, or if I should just go with a new replacement.
So far, the repair considerations are:
1. Use a rubber cement on the underside.
2. Use silicone sealant on the underside.
3. Use a bicycle tire repair kit on the underside.
My concern with glue type repairs is that a mid-woofer works on air pressure, a weak spot in the rubber may affect performance.
4. Have the rubber surround professionally replaced.
5. Buy a new driver.
Thanks in advance!
Old 22nd July 2007, 05:34 PM   #2
colonelkernel8's Avatar
Send a message via AIM to colonelkernel8 Send a message via MSN to colonelkernel8
I am no expert, but I would imagine that whichever solution will provide the lightest, most flexible mend would be ideal.
Old 22nd July 2007, 06:01 PM   #3
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Glue with Latex gloves ?????
Andy
If it ain't broke, break it !! Then fix it again. It's called DIY !
Old 22nd July 2007, 06:16 PM   #4
Speakerholic
Cal Weldon's Avatar
Default Re: Tear in Driver Rubber Surround
1. Yes, clean the rubber with alcohol first and use a small bit of tissue to act as a scrim.
2. No, silicone is not known for sticking to rubber or neoprene.
3. No, too much added mass.
4. Only if you're a quitter.
5. Heavens no unless the repair goes awry.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 27th July 2007, 09:00 PM   #5
Thanks all for the great responses. After searching the web for different ideas, I ended up going to a bike shop to see if there was anything that might do the trick. Agree with Cal's comments that a bike patch kit is too much added mass, but found a product that is paper thin, elastic and made to repair expandable thin rubber tubing. It's called "Flat Boy" #542-3700 and is a bike tire self adhesive tube patch kit. The tear is now completely repaired and invisible. Cut a small piece of patch (to size) and applied it to the bottom of the rubber surround with tweezers. Gently pressed it on with my fingers and presto - repaired.
Photo - the tear is at 6:00. Hope the photo shows up.
This might be of benefit to someone that makes the same mistake I did.
Foam vs Rubber surround walker Multi-Way 88 30th June 2007 04:38 PM
punctured rubber surround alvinlim Multi-Way 9 3rd April 2006 04:37 AM
Gluing rubber surround to paper cone biff_loman Multi-Way 4 10th August 2004 01:13 AM
What type of glue for butyl rubber surround repair? c_h_shin Multi-Way 0 19th May 2004 05:37 AM
Rubber surround coating??? Harryo Multi-Way 0 28th February 2002 09:47 PM
Page generated in 0.13622 seconds (52.49% PHP - 47.51% MySQL) with 11 queries
