I stumbled across these for $5 and could resist trying them. It looks as if the company has expired. The whole kit contains two inflatable speakers, a chip amp the size of a computer mouse (2W downhill with the wind; it appears on the chips datasheet), a case to hold six AA batteries (cleverly velcros to the bottom of the amp), a wallwart, and a nylon bag. It brings to mind the Sonic Impact set that included folding cardboard speakers (which I have and use the same licensed NXT technology).
They sound terrible. I plugged them into my EMAC. With the volume cranked on the control panel and the amp they still can't produce much sound. They do move an amazing amount, though. They are painful to listen to. Claimed response is 50-20K hz. That may be true +/- 20db. The cardboard SI's crush them (as I assume the SI amp crushes this little amp.) I couldn't photograph the workings well. A fairly regular (but incredibly cheap looking) voice coil/spider/tiny motor is glued to a square of corrugated plastic (white in the picture.) The whole thing shakes the inflated part. Evidentally these folks had plans to build a home audio version. Though not particularly relevant to anything, I thought some of you might share my amusement. If anybody wants a set, drive up here. There are plenty more from where mine came. pj |
#2 |
Having problems -w- the pic. . .
#3 |
diyAudio Moderator Emeritus
That is a novel idea indeed.
Anyone have any balloons with a large elastic opening? Or perhaps some lighter material like mylar? You could inflate (air, helium, hydrogen = boom) a balloon and seal it around the frame of a small driver to achieve something better I would imagine. You'd think that would be pretty omnidirectional, no? I can see problems with gas leakage though...
Brian |
#4 |
You get really good bass with hydrogen. once. 130dB/W/m should be easy. Mind the glass fragments on your lawn afterward.
#5 |
It would be a full range. Transient would be good, again once. You need the right amount of oxygen though. Mix in some Condy's crystals and you could play purple rain, following the bang.
#6 |
Now range of speakers: R101 & Hindenburg anyone?
#7 |
Hi all.
They seem to be particularly adept for 1 piece of music only. The 1812 Overture, but with a real cannon (????) |
#8 |
I actually know the guy who invented the cardboard NXT speaker although he would never publicly put his name to it, and I once asked him, after he said they are great for outdoor barbeques and the like, "how do you compensate for the falling treble response and is it in proportion to the amount of rain that is falling at the time when outside?". After receiving a couple of ery well educated profanities, I decided a tactical withdrawal was best.
| The inflatable travel speaker concept | davepenney | Multi-Way | 21 | 9th May 2007 04:08 AM |
| Fullrange 100 hz and up | Nate_Taufer | Full Range | 14 | 12th October 2005 03:15 AM |
| Fullrange for me? | bjackson | Full Range | 13 | 31st August 2005 09:55 PM |
| fullrange | tomtt | Full Range | 6 | 12th July 2005 02:11 AM |
| fullrange or 2.5 way?? | AudioGeek | Full Range | 2 | 18th August 2004 07:26 PM |
| Page generated in 0.13663 seconds (71.92% PHP - 28.08% MySQL) with 11 queries |
