Fe167 and wiring? - diyAudio
Old 15th July 2007, 02:24 AM   #1
Default Fe167 and wiring?
Im just putting together the official Fostex cabinet for the FE167es now before you tell me this isnt the best cabinet I know. This is just a bit of fun as I think the port in the speaker stand look cute. These drivers are eventually schedule to end up in MKs - ML TQWT which should be a lot better.
This is mainly targeted at Scott whos regularly recommended a twisted pair of strands out of a Cat5 cable per connection internally. Scott I actually use a single cable of Cat5 for my speaker lead 4 of the 8 twisted together to form a single lead (either + or -). I would normally just do the same inside the speaker am I over dampening the drivers wiring like this.
My power amps are Musial Fidelity X-AS100s or sometimes an old MF A100
http://www.greenie512.net/greenie512/html/wip.html - details
Cheers - Phil
Old 15th July 2007, 09:03 AM   #2
Scottmoose's Avatar
They might not be the highest performing design for the 167, but those look very good to me.
No, you won't over-damp the drivers. A high DF amp just won't compensate for the LF roll-off of a low Q unit (thanks GM). Having said that, a) the MF amps, as SS goes, don't have an especially high output impedence, and b) the FE167E isn't a low Q driver -it's got quite a nice mid Q, so it'll work happily enough with most any amp anyway. So you should be fine. The thin wire is just a useful trick that can sometimes be pulled to tweak a particular combination -it's best not to use it as external wire for a speaker with a BSC circuit for example.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 15th July 2007, 09:05 AM   #3
ttan98 is offline ttan98  Australia
More importantly, how does it sound?
I have a pair of FE167 as well.
Old 15th July 2007, 09:12 AM   #4
Scottmoose's Avatar
As do I. One of Fostex's finer moments, and especially good in MLTLs or MLTQWT. Not so good in a pipe-horn though -they'll do fine, but they demand a relatively large box of this type compared to, say, the 165 or 166. No free lunches in audio unfortunately. I was going to put mine in pipe-horns, but the size demanded a bit of a re-think as I don't have much space at present. An MLTL is probably what they'll find themselves in, and save the pipe-horn for the 165 / 6.
Old 15th July 2007, 09:18 AM   #5
Scott - Thanks, have just wired up with cat5 and ran for 45 mins.
Ttan98 - for 45 min they so pretty dam good, might be a bit edgey but that'll smooth with a bit of run-in. Not bad bass either? If you didn't want large cabinets these see pretty good. But there are other solutions!
I'm always impressed with the way Fostex reproduce the human voice - luvly ....
Cheers - Phil
Old 15th July 2007, 01:00 PM   #6
Bob Brines's Avatar
I have to admit that I never built a pair of the Fostex recommended cabinets for the FE167E, although I have looked at the modeled performance.
This cabinet was clearly designed for HT with a dedicated sub. The box is actually too small for stand-alone use. It has a peaked response at cut-off. This peaking does two things: It partially takes care of the BSC and it provides better power handling. They need to be powered by an HT receiver and assigned as "small" with a cut-off around 100 Hz. Then you will be able to drive them at insane SPL levels.
I prefer the FE167E in an MLTL rather than a TQWT. For the money, this is about as good as it gets. When doing a BR, I prefer a moderate ESB alignment. For the FE167E, I like 24 liters tuned to 45 Hz.
Bob
Old 15th July 2007, 01:11 PM   #7
Scottmoose's Avatar
I haven't modelled it, but what you say about the alignment doesn't surprise me Bob, as Fostex seem to favour it in their other BR cabinets that I have looked at. If there isn't sufficient house-room for some large variety of horn (and with a mid Q & Vas, volume needs to be pretty high), the MLTL seems favourite for them to me too. Oh for a larger space. ;^)
double Horn for FE167 Spassgeneral Full Range 29 20th February 2008 08:37 AM
enclosure comparisons for FE167 ? pasomark Full Range 0 23rd August 2005 11:47 PM
fe167 harsh tenderland Full Range 33 15th February 2005 03:02 AM
Jx92s Or Fe167??? AudioGeek Full Range 2 20th August 2004 07:42 PM
Scott's FE167 ML-TLs SCD Full Range 9 24th February 2004 08:31 PM
Copyright 1999-2017 diyAudio
