Old 10th July 2007, 10:39 AM   #1
skogs is offline skogs  Norway
Default sono-speaker b3s
Hi, im going to build a speaker using the b3s full range and zaph's filter. http://www.zaphaudio.com/audio-speaker18.html
zaph specifies among other things that the edges of the baffle should be rounded, and that the speaker should not be placed directly on the deskboard due to early reflections.
So i just wondered if the design on the picture will have any noticeable affection on the sound due to reflections. im thinking about the little pieces on the top and bottom thats going to be about an inch at the most past the baffle. Could this worsen the sound?
thanks for help
Old 10th July 2007, 11:24 AM   #2
sreten is online now sreten  United Kingdom
Slightly. Assuming you are making grilles an internal bevel is all that is needed.
If you are not making grilles then I cannot see the point of including the pieces.
Placing the driver around 5/8 up, 60% will give an improvement.
/sreten.
Old 10th July 2007, 06:50 PM   #3
yes, im planning on making a grill, like the one on this picture, and then use grill cloth around the whole speaker.
do you mean a driver placement thats something like this?
Old 10th July 2007, 07:48 PM   #4
You could simply bevel fill that section. I meant driver centre is ~ 60% up.
/sreten.
Old 10th July 2007, 07:56 PM   #5
/sreten.
Hi again, sorry, i dont quite understand what you mean, could you try to explain a little closer?
im sure its just me thats a little slow after a hard days work. I really appreciate the help!
so you mean that the centre of the driver should be placed with a distance ratio of 40\60% between top and bottom of the speaker?
and what do you mean by bevel fill? that i should round the edges of the pieces thats past the baffle?
thanks again for helping
horn vs sono subs... what to build? carvernut Subwoofers 14 25th September 2007 05:09 PM
Sono Tube wingman Subwoofers 3 30th October 2006 05:56 PM
Anyone familiar with the Jensen Sono-Dome Ultra tweeter. Shoog Full Range 2 1st June 2005 08:36 PM
18" sono sub? Kozmic Subwoofers 1 31st January 2004 03:55 AM
Top heavy sono sub eRiCdWoNg Subwoofers 4 29th December 2003 03:32 PM
Page generated in 0.10227 seconds (64.35% PHP - 35.65% MySQL) with 11 queries
