Transient-"perfect" 2nd/1st order crossover - Page 3 - diyAudio
Old 25th January 2013, 10:07 AM   #21
The best compromise regarding overlap etc is IMO a filter with a Q value of 0.5 (aperiodic).
For every filter with a Q equal or less than 0.5 the denominator can be broken up into two first order parts, while a Q value 0f 0.5 is the easist of all cases because both parts are equal.
The higpass will be built by EQing the FR accordingly. We want to go for a Q of 0.5. The pole frequency (-6dB point for a Q value of 0.5) will be one octave below the acoustic crossover frequency.
The lowpass part
(1+sT/0.5)/(1+sT/0.5+s^2T^2)
can be split up (don't know the appropriate term in English) in several ways.
The one already shown as circuit example was a 2nd order lowpass multiplied by the sum of a differentiator and a linear function. This had the advantage of being able to adapt to the woofer's upper rolloff to some degree.
OTOH we usually don't like differentiators that much in practical circuits.
Another way of splitting the lowpass function is the sum of a second order lowpass and a 2nd order bandpass. In hardware this would be easy (although there wouldn't be a big advantage because of the increased amount of components). But the easy DSP crossovers wouldn't like that because of the summing function.
The third way to split the lowpass function would be the product of a first order lowpass and a first order lead filter ("high shelf"):
(1+sT/0.5)/(1+sT/0.5+s^2T^2)=((1+2sT)/(1+sT)) * (1/(1+sT))
Theoretically it should be possible to abuse the woofer's baffle-step function for the lead filter if it should happen in the proper frequency range accidentally. But for most applications the use of a first order lowpass followed by a high-shelf would be the weapon of choice. This simple solution now has the disadvantage that we can't take the
woofers top-end response into consideration that easily with the crossover function alone. But the extended EQ functions of DSP crossovers would allow easy driver EQing. And there is another thing that these crossovers offer and which cannot be implemented easily in an analog way: Delay!!!
The phase-response a the upper end of the woofers respnse is usually the worst contributor to bad signal summing. OTOH a lowpass can be regarded as having a more or less constant group-delay within its passband. So it is advisible to not try to exend the woofers response at the upper end in order to achieve the proper phase response but rather EQ it to behave like a well-tamed lowpass and then delay the FR accordingly. It would even be possible to add another lowpass to the woofer's response as long as it is not too close to the xover frequency. The best situation would be if the woofer's natural response and the additional filter form a Bessel filter (which has constant group-delay within its passband) but that may be asked too much.
So our crossover would look like that:
FR:
[HPF] -> [LT] -> [BSC] - > [delay] -> [misc EQ]
HPF: Highpass filter emulating the woofer's low-end response or even emulationg its equlised low end response if necessary.
LT: Linkwitz transform making the FR behave like a 2nd order highpass having a pole frequency of 0.5 * fcrossover and a Q of 0.5
BSC: Baffle step compensation
delay: Delay equal to the group delay of the woofer's natural (or equalised) lowpass behaviour.
misc EQ: Equaliser stages used to tame the FRs frequency response.
Woofer:
[LPF] -> [HS] -> [misc EQ]
LPF: First order lowpass with a -3dB frequency of 0.5 * fcrossover
HS: 6dB high shelf with a mid-frequency of 0.71 * f crossover
misc EQ: Equaliser stages used to tame the FRs frequency response, eventually including an additional lowpass.
An LT might also be used for the woofer in order to extend its frequency range but take care of the summing with the FRs response.
Hope this will help for playing around a little for those interested.
I will soon post rules of thumb for the asymmetrical 3rd/1st as well and also for the symmetrical 2nd/2nd.
BTW: The high-shelf and first-order lowpass chain can be implemented in hardware in two simple ways. Both are using one OP-AMP, three resistors and two capacitors. One variant can be used only for Q-values <= 0.5 and the other one is more flexible.
Charles
Old 25th January 2013, 01:53 PM   #22
Originally Posted by phase_accurate View Post
Here we are dealing with the classic constant-voltage crossovers that don't use any form of subtractive delay simply because of two reasons: They can't be built easily using analog methods (although I know at least one practical example which is a "mass grave" of allpass filters)
True -- they can be created in analog, but not easily. (Ng and Rothenberg used analog delay lines.)
or digitally using these DSP crossovers that are configured by the use of a convenient but restricted GUI.
If you can create a Bessel lowpass filter and a delay within your GUI, then you can create the kinds of crossovers described in my paper.
Forgot to get into the crossover order discussion. I am totally aware that a second order acoustical rolloff doesn't exactly mean perfect driver protection.
That seems to be the most common complaint about the 2nd order HF rolloff of the Gaussian/Bessel-derived subtractive delay crossovers. I guess my response is that, if it's a problem, then raise the crossover frequency or use a better HF driver.
Greg
Old 25th January 2013, 02:13 PM   #23
The "HF drivers" used here are fullrangers and therefore much more robust than domes. So the method shown here should work quite often. It is not accidentally that I posted it under the fullrange forum.
The GUIs of the cheap and convenient DSP crossovers let you define Bessel and delay. So far so good. But they usually only let you define chains of filters without any branching, addin or subtracting. And this is what would be needed for filters you describe.
But they would definitley work nicely for FAST systems, even those that only give a second order response for the highpass section.
Charles
Old 25th January 2013, 02:24 PM   #24
Frankly, I hadn't noticed that this was in the fullrange forum; my mistake. I guess I am a bit mystified as to why crossovers are being discussed for fullrange systems.
The GUIs of the cheap and convenient DSP crossovers ... usually only let you define chains of filters without any branching, addin or subtracting.
Ah, that would be a problem.
Greg
Old 25th January 2013, 02:30 PM   #25
The so-called FAST systems are increasingly popular amongst DIYers.
FAST = Fullrange And Subwoofer Topology
And there is also some interpretations like "Fullrange Assisted ...." but I can't remember exactly how it goes. But both mean the same: A small fullranger that is getting low-end support by a larger woofer.
Charles
Old 25th January 2013, 03:01 PM   #26
Thank you; now I understand.
Such a system would seem to be ideal for the Bessel-derived subtractive-delay crossovers. The subwoofer LPF rolls-off at an extremely steep rate, so the subwoofer "gets out of the way" very quickly and does not intrude upon the fullrange's splendid response from midbass upward. Furthermore, if the fullrange naturally rolls-off at 12db/octave, then with some delay (and perhaps a bit of EQ) that natural rolloff can be incorporated as an approximation of the perfect-reconstruction subtractive-delay. Mathematically it's pretty easy to express; implementation might be a bit more difficult.
Greg
Old 26th April 2015, 08:51 AM   #27
hahfran is offline hahfran  Germany
Charles
I experimented with "FAST" for about 20 years, using Jordan and Manger as fullrange. Listening tests , even professional musicians participating, supported the "psychoacoustic" claim that the crossover frequency should be 150 - 200 Hz. As the frequency/amplitude statistics of classical music has its max between 200 and 500 Hz, the Fasts are simply unable to reproduce the dynamic range. In best case , compression, worst case huge distortion.
Going up with crossover frequency to 500 Hz, these limitations are avoided,
but the the time/space resolution is gone, too.
As for the filters, nothing beats a "self-calibrating" DSP that optimizes frequency and pulse response at the actual listening position, such as the "Dirac" software.
Old 26th April 2015, 11:09 AM   #28
Further in about 2001 i used only current drive , the mechanical parameters of the drivers compensated by an "analog computer" solving the motion equation B*l*i= {acceleration} + {velocity} + { displacement } such that the crossovers deal with a "idealized" driver. Of course the motion equation is valid for all electro/mechanical transducers, hence for Manger, too.
Old 6th August 2015, 09:38 AM   #29
I haven't noticed that this thread popped up again recently.
Just using a self-calibrating solution is not very DIY unless you have at least written the program that does this and/or built the DSP solution by yourself.
As far as the topology goes that was presented here I have some add-ons regarding its use with DSP crossovers.
The function for the highpass channel can be adapted 1:1 with solutions like Mini DSP etc.
For the lowpass channel the following can be said. As long as the crossover's Q is 0.5 or below the lowpass function can be built using a first order lowpass and a high-shelf. The amplitude error of the intrinsic lowpass function of the woofer itself doesn't usually show up strongly in the summed response. The phase roation of this lowpass function has a more detrimental effect. But this can be compensated for by introducing a delay into the highpass path (i.e. delaying the tweeter by the same amount as the group delay of the woofers intrinsic lowpass function). It should even be possible to introduce an additional lowpass filter in the woofer branch that has its cutoff frequency between the crossover frequency and the woofer's natural rolloff. This would also have to be taken into account for the setting of the delay in the tweeter branch.
The resultant amplitude error should actually be minimum phase and could therefore be EQed out easily.
If done well this crososver should beat the Harsch crossover in terms of transient acccuracy but this would come at the cost of worse lobing and a slight hump in the power response.
An MTM arrangement woul help against the asymmetrical lobing to some degree.
If more detail is needed I can assist.
Charles
Old 6th August 2015, 11:21 AM   #30
xrk971 is offline xrk971  United States
xrk971's Avatar
Charles
I have tried the 1st order on the woofer with added high shelf. It was not as good as 4th order BW at controlling leakage of woofer breakup into the full range's mid. So far, the Harsch is best sounding for me and much easier to implement.
MCM Order has been "Waiting to ship" for a week... is this normal? MikeHunt79 Everything Else 6 29th November 2007 02:44 PM
Beyerdynamic's Headzone headphone promise "perfect spatial impression" Nordic Headphone Systems 1 28th August 2007 09:10 PM
1st order ? L-R 2nd order? or transient perfect?? Ken L Multi-Way 6 17th October 2003 04:22 PM
6th order crossover for eclipse 6.5&quot; nillahcaz Car Audio 0 24th July 2003 09:31 AM
"transient-perfect" crossover in 12/02 AudioXpress dorkus Multi-Way 41 25th November 2002 07:23 PM
Copyright 1999-2017 diyAudio
