Hello,
I want to build an Sachiko. But which would be the best chassis for this cabinet (I don't like the fostex fe206e because of it's frame-style ).So have searched for this alternatives: Audio Nirvana Super 8 (maybe the cast frame) Fostex FE206ES-R Hemp FR810HQ Lyeco LY802F Supravox HP215RFT64 So, are these alternatives equal for the Sachiko or are there some "no goes"? Thanks Armin |
#2 |
You are obviopusly a man of taste and decency.
OK, the Lyeco & Supravox are out -Q is too high for this cabinet. The Hemp is borderline, though again Q is a little high, and it wouldn't be my first choice. The FE206ES-R works very well: there's already a pair of Sachiko's using them to good effect. And the Audio Nirvana Super8 cast-frame should work fine too. For myself, I never found the FE206E as unattractive as all that though... Hope this helps Scott |
#3 |
... it helps (but I don't like the result). So I must build a blind/faceplate for the chassis.
Is only the Qts is relevant for the cabinet (<0,4)? Thanks Armin |
#4 |
I thought you liked the ANS8 cast frame & 206ES-R? As I say, those will work fine. The FE208ESigma (you'd need to add a tweeter to that -the FT17 is a nice unit, and not particularly expensive) should do a decent job too.
Q is not the only factor, but it's one of the most significant ones. Vas and Re are also important. As a rule, the higher the Vas, the larger the cabinet you'll need. Re also affects the shape of the response. Best Scott |
#5 |
#6 |
Very beautiful!
I' m beginning to build an identical project: AN super8 cast frame in an sachiko enclosure!!!!... but how it sound? Can you indicate me perks/flaws of this combination? Thanks |
#7 |
Very nice indeed. How do you find they sound?
Best Scott |
#8 |
DOH!
Today I was in a wood store.... i asked for finnish birch plywood and they want 450 euros.... Definitely to much for my money. Sad, but true. Anybody can say me wich kind of wood could I use for a good sonic performance at a more human cost? (ps: I find mdf not so actrattive.... veneered, more cheap alternatives?) Could I alternate birch with other wood in the same cabinet? Thank anybody for answers |
#9 |
You could try a mixture of birch ply & ordinary, cheap chipboard (particleboard), with the ply for the side panels, and, if there's sufficient, the rear panel, and the chipboard for the rest. That should cut cost somewhat & work pretty well.
#10 |
That's could be an idea.... but the side/rear panels are big and I could save only a few money.
What's the result using mdf for side-rear panels (obviously less fashionable, but I must wait the day that I become rich! and russian birch ply for baffle / horn panels? BUT I've read that mdf can sound harder and harsher.... (but particleboard is to horrible outside the cabinet!!) Isn't true? Ps:Thanks Scott |
| Sachiko | drvomir | Full Range | 14 | 26th August 2011 07:00 PM |
| Sachiko's are done ! | hifisucks | Full Range | 15 | 26th May 2009 07:55 AM |
| another Sachiko build | ljk11 | Full Range | 17 | 26th January 2009 01:34 AM |
| Half Sachiko | Assesears | Full Range | 1 | 19th September 2008 06:24 PM |
| Page generated in 0.13539 seconds (68.32% PHP - 31.68% MySQL) with 11 queries |
