as in comparing its distortion with say 206E? which is cleaner up to 1.5mm stroke?
#2 |
hello Freddi,
o,3 mm to bad for bass, http://www.fostexspeaker.de/fullrang...ie/ff225k.pdf, compression and distrotion below 1 W also in a horn.
http://www.hm-moreart.de |
#3 |
Hi HM -
for a 186 liter 2.5M BLH, 0.3mm would allow about 1/5 watt input to reach 0.3mm around 55Hz. Eminence revised their ALpha 6 which had winding height ~equal to gap height and now calls it "3.5mm" using some distortion figure. I think they did the same with 12LT which is now called "12LTA" some drivers have a pretty good fringe field - I think Altec 421 is one. does 225K go out out control fast when past 0.3mm? does too much stroke in a fullrange or wideband invite audible modulation distortion? Best Freddy Simulation of 225K vs 206E wall + floor boudary http://img146.imageshack.us/img146/3...hff225kpv6.gif |
#4 |
In sonic terms they don't appear to loose it too badly at all -I was listening to a pair in Will's Jericho horns a few weeks back, and they sounded very nice indeed. They work well in pipe-horns too, as do the 165s, although I suspect the technical performance wouldn't look so hot, so YMMV as ever. Luckily, the distortion is going to be in the LF, where our hearing isn't great. From that, I suspect the distortion rise is pretty gradual. As Nelson commented elsewhere, probably best not to feed them the Jurassic Park soundtrack, but so long as you don't go crazy, they're a nice listen.
#5 |
Isnt it a midrange intended to be used with a big woofer ?
#6 |
Custom Title
I use a pair loaded with Rethm The Second cabinets (Odd horn/acoustic labyrinth hybrid) and they can generate enough output for my small room, getting beyond xmax and do just fine there. People get way too hung up on specs, the arrangement of similar gap and voicecoil height looks bad on paper, but sure sounds good here.
It's a very smooth and clean sounding driver, I think they struck a good balance between bandwidth and linearity. hell of a motor on it.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#7 | |||
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#8 |
I just recently built a horn and installed an FF225K in it. I am in the process of aquiring the necessary equipment to be able to measure its response. The horn is tuned to ~ 35Hz, and is about 2.65m long. The Sd/St ratio is 4:1. I see that this driver (Going by eye) has no problem with 2-3mm of excursion. The speaker is very smooth sounding and has surprising good and low bass. All I can say until I do the measurements is that if I compare it to my FE208E Sigmas in the BK20, the bass is lower and it is louder when driven at the same wattage.
I kind of asked this question on the Fullrange driver website. If the SPL of the bass is really based on volume/velocity, couldn't a driver especially when horn-loaded make up for its xmax in the strength of the motor? Strong transient response resulting in higher compression/amplitude of a smaller volume? |
#9 |
Custom Title
That's what compression drivers are for awhite. If you want them to go low..... they're gonna be big and COST.
The FF225k has a great response curve compared to other high-efficiency fullrangers- relatively smooth without the brutal top octave breakups and whatnot, better to use a tweeter (or a supertweeter) than have to deal with those shennanigans. The bass response is also fairly good compared to 'rising response' style drivers (which are generally quoted as more efficient, but have less actual output) Short version- this driver isn't meant to flop around, but this style of driver can be overdriven without horrible sonic penalties (anyone remember how unfounded people's concerns about the .5mm xmax of the Audax PR17OMO were? Lots of high efficiency and pro midrange drivers have limited Xmax, but don't misbehave the way you might expect when overdriven.
#10 |
I think application of horn-laoding can make up to a point - especially vs direct radiator
looking at sims, some horn can interchange 6" and 8" drivers with little response change - but the smaller driver will have more excursion overall how much excursion is permissible with fullrange say on a passage with flute and sustained electric bass notes before modulation and gargle become too much? FF225 sim with ST,Sm ,CC fixed varying path length and bulk http://img182.imageshack.us/img182/1...m25m35mvs7.gif FF225 max ouput at 0.3mm, 1mm, 2mm & 3mm strokes http://img182.imageshack.us/img182/9...aryxmaxfy9.gif |
| FLH with FF225K, anyone? | CLS | Full Range | 6 | 9th June 2009 04:23 AM |
| BIB with FF225K+FT17H | testarossa2k | Full Range | 4 | 19th November 2007 07:29 AM |
| cap for ff225k and ft17h | testarossa2k | Full Range | 2 | 29th August 2007 09:44 PM |
| Effect of exceeding XMAX in real life | jondoe | Multi-Way | 18 | 25th May 2005 05:40 AM |
| Page generated in 0.13303 seconds (75.39% PHP - 24.61% MySQL) with 10 queries |
