I'll be getting my hands on a pair of Philips AD12202-M8 next week but can't seem to find the T/S specs on the web for it except the Fs of 45Hz. Does anyone have the rest of T/S information that they can share? Also, I'm wondering which type of enclosure will suit these drivers, a TL variant or BLH? I'm very new to diy speakers and can probably handle a simple TL variant design, but will probably have to engage an experienced woodworker for a more complex BLH design. I'm wondering if the MLTL-48 design listed at this website http://www.ejjordan.co.uk/diy/index.html will be suitable, or the Bruce BVR or Sachiko Nagaoka-Style enclosure. Will the triangular MLTL-48 design work as well? Thank you!
Having limited resources, I'll probably put the Altec 409-8 project on hold first. |
#2 |
I just found a spec sheet, but it is in German: http://www.rahaso.de/foren/msg.php?f...nge&idx=18657&
Here's a translation with the help of babel fish: nominal impedance 8ohms d.c. resistance of the moving coil 6.6ohms load rating 100W max load 150W output 0.5W resonant frequency 45Hz through howling tension (lost in translation?) 9V transmission range 50Hz - 19kHz magnet material FXD magnet diameter 124.6mm magnet mass 990g energy in the air gap 498mWs magn. flow density 1110mT air gap height 8mm height of the moving coil 9.7mm minor diameter 35mm basket diameter 313.3mm sound opening/free space 278/5mm depth 135mm mass of the loudspeaker 1650g |
#3 |
I have a pair of these chassis laying around here and I'm searching for TSP aswell. Unfortunately I don't have any more parameters than you already have.
I am a bit concerned about the tin basket, if you hit the basket with your fingers, a screwdriver or something else, it makes this high *tiiiing* bell-like sound. That is, probably, only if the chassis isn't mounted but I think it would be a good idea to glue some damping material (foam rubber?) onto the basket. The enclosure on the link you've postet won't work because the speaker doesn't fit into the enclosure (not even nearly I guess the chances are higher to get these chassis get to work or let's say, 'sound halfway decent' if a new cabinet design is I thought about trying a br/horn comination for the chassis. Anyone with some ideas maybe?
#4 |
Found more information on the drivers here: http://www.mfbfreaks.nl/html/nieuws/archief2005.htm
and here: http://www.mfbfreaks.nl/pdf/div/phil...ekers_1984.pdf But still no luck on the Qts, sigh... |
#5 |
may be somthing here
http://www.vt4c.com/bb/viewtopic.php?t=1010 音響制作工藝 DIY Audio Craft :: View topic - Philips Full-range 12" 9760 TQWT
none |
#6 |
and here?
http://www.vt4c.com/bb/viewtopic.php?t=1346 音響制作工藝 DIY Audio Craft :: View topic - Philips EL7032/01 full-range specs available now
none |
| FS Alnico Philips AD3800M AD3800AM and Philips transformers | guglielmope | Swap Meet | 8 | 10th January 2011 11:28 AM |
| philips cd 880 philips cd880 service manual | 0519 | Digital Source | 4 | 28th August 2008 11:43 AM |
| Philips CD 720 mod advice needed... | mickie | Digital Source | 1 | 27th November 2007 06:00 PM |
| Advice regarding philips/mullard EL34 | kmj | Tubes / Valves | 11 | 29th April 2006 02:20 AM |
| Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice | moving_electron | Chip Amps | 0 | 16th February 2005 12:37 AM |
| Page generated in 0.10465 seconds (73.23% PHP - 26.77% MySQL) with 10 queries |
