Hi guys/gals!.... there are just SO MUCH systems to aspire to!!!...
Been a lurker for a while, and have read pretty much every thread here, taken me about 6 months :-) I want to build some harveys or larger frugal spawns, but I'll start with something simple first. So I think I'll be whippin these up for my first speaker project, as they are basic rectangles and small. :-) Based on Planet10 fe127 hifi fonken tuned floorstander MarkII, only it was done with 15mm material, but I could only source 12mm, but kepping the internal dimesions the same. picked up some 12mm marine ply as best I could 3 out of 25 sheets with no knots front/back. I have done a quick sketchup of the design, these are designed for full range single driver fostex fe127, and thats what I'm going to fit in them, but I also thought I might leave a curved top on it to add a tweeter at some stage if the highs did not get there with the fe127e's. 2 x fe127's on order, but I had some 100mm paper drivers with whizzer's sitting round I thought I'd throw them in till the fe's turn up. sketchup of speakers: Back: front: Exploded: Gluing the holey brace in place: ![]() Another angle: ![]() finish will probably be nude wood, with some sanding priner? and a light stain with a couple of clear coats. My edges are VERY rough as I used a circular saw to cut them out and a few peaks and troughs around the edges :-) I think my next version I'll take the cut list to my wood supplier and get them to cut them out more exact than what I've done so far. I could have used a straight edge clamped to the wood thinking about it in hindsight, but I just cut em out. might do that next time, but anyway, will have these glued together and ready for testing by the weekend. |
#2 |
I'm building my first fullrangers at the moment, and experiencing the same problems with getting neat cuts. I found this today, the sawboard which looks like a great idea, and will use on my next project. Your project looks great, don't you just hate having to wait to hear how they sound though !
#3 |
That does look like a good tool. I am going to build at least one pair of Metronomes in the fall and one thing I'm concerned about is getting the angle cuts to all be the same, so maybe the sawboard with an angled cleat at one end will give me consistent cuts.
Use a router with a pattern following bit and straight edge to take out the peaks and valleys, or at least the peaks. Or for square sided boxes, glue it up with the peaks protruding over the side and use the side as the straight edge, with a flush cut bit. |
#4 | |
http://www.diyaudio.com/forums/showt...66#post1247866 |
#5 | |
Doug |
#6 |
how brilliant is that!... a saw board...
just did a google and found a couple of sites but this was a good explination:http://members.aol.com/woodmiser1/sawbd.htm gonna build one tonight and test it out on speaker2 :-) that finishing technic looks tops! going to try that too. spellings a bit off, posting on my pda :-) |
#7 |
#8 |
frugal-phile(tm)
You don't realize how small these are until you stand next to them... 12mm material is fine... Chris & i sort of decided to standardize on 15mm for most everything so we could justify buying a lift at a time (and then they ran out of 15 for a bit) So we are now working thru a lift of 12.
Here is a picture of the original build of these for inspiration, now residing in NY, NY dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
Now for speakers, especially floorstanders, those are cute.
#10 | |
what this set of pictures doesn't fully reveal is the nice wrap-around grain matching the small enclosure size allowed
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
| Service Manual Request: Marantz CD75 MkII or CD65 MkII | jeff mai | Digital Source | 9 | 23rd April 2009 04:48 PM |
| Fonken floorstander MKII | ecir38 | Full Range | 68 | 18th November 2008 02:00 PM |
| 1st timer building Fonken Floorstander MkII with Planet 10 FE127eN drivers | rbclark | Full Range | 33 | 24th April 2008 07:25 AM |
| 3 Way floorstanders | jjbmon | Multi-Way | 3 | 26th January 2008 08:45 PM |
| Page generated in 0.13604 seconds (76.37% PHP - 23.63% MySQL) with 11 queries |
