Playing thru the SI amp and a portable cd player as the source.
Hope the drivers are ok. I will troubleshoot later in the week. I recently connected my small Infinity powered sub. But even with the sub unplugged (wires still in the SI terminals), the speakers just go hmmmmmmmmmm. Turning the volume knob doesnt change the sound. No music plays at all. Would anyone know what this could be? |
#2 |
not the speakers, WOuld probably be your ampo because the volume doesnt vary.
#3 |
Rest easy, it is the amp. Speakers on their own can't hum. It sounds like the amp has gone DC, feeding ripple to the speakers.
Leave the speakers disconnected when you power up the amp next to avoid toasting the voice coils. Measure the voltage at the amp output. It should be close to zero. Geoff. |
#4 |
Guessing the chip may be fried and that may have been due to excess current draw through the SI ground. Infinity grounding scheme may have created a high current ground loop through the SI. Check the small ground choke separating the analogue and power grounds in the SI. Are the ground tracks and connections in tact?
#5 |
Maybe they are humming cuz they dont know the words. ron |
#6 |
>>> Check the small ground choke separating the analogue and digital grounds in the SI. Are the ground tracks and connections in tact?
I will try to check that. I have confirmed it's the amp. It hummmmms on the Pioneer/Piezos too. Luckily, the speakers are fine (the Pioneers that is. Havn't yet checked the 127s). Yeah, the variable was the Infinity subwoofer. It did work the first few times i used it. Then i let it sit for a week or so and when i turned it on everything hummmmmmmd. I hope the SI amp can be made to work again. I'd like to modify it. If not, i'm glad it only cost $30. Thanks, Godzilla |
#7 |
I suspect your sub toasted your SI. There is something about the way some speakers are grounded that the T-amps do not like. I tried searching in the Class-D forum but could not find it. I know it's there somewhere. Sorry I can't be more specific, but it's something to do with the ground and how the T-amps are built.
Doug |
#8 |
might be too late for this current SI amp, and I certainly hope the drivers are OK., but you might want to check out our dear friend Ed Schilling's website/forum regarding the magic box to make safe this type of connection:
http://www.audiocircle.com/circles/i...?topic=38384.0
you don't really believe everything you think, do you? community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi |
#9 | |
http://www.thehornshoppe.com/Magic%20Cable.html |
#10 |
Short and sweet answer: bridged output amps shouldn't have anything but floating loads. A powered subwoofer should have a way to "float" the inputs otherwise it will short one of the "halfs" of the bridge to ground. It will depend on the specific amp what will happen.
Many subwoofers plate amps have a visible bridge between the (-) input to "ground" that can be removed for this specific case of bridged amps. I'm sorry Jeff but I think the amp went south... Gastón |
| did i blow out my fostex 127e's? | crappyjones123 | Full Range | 8 | 16th July 2009 05:54 AM |
| Fostex 126e or 127e | germpod | Full Range | 71 | 9th May 2008 07:26 PM |
| Fostex 127E phase plug install | kazoo | Full Range | 42 | 11th December 2006 07:54 PM |
| t-amp with fostex 127e bipole or FR125 bipole? | alexg | Full Range | 6 | 23rd August 2006 07:49 AM |
| 127e in oversized box | Godzilla | Full Range | 2 | 8th February 2006 10:37 PM |
| Page generated in 0.13251 seconds (74.52% PHP - 25.48% MySQL) with 10 queries |
