Old 28th June 2007, 07:50 PM   #1
Question Please help this newbie out!
I have been a longtime lurker over here and I have finally decided to embark on my first DIY loudspeaker project. I have set my sights on the recommended Bass Reflex for FOSTEX 127E. It is a 10Litre box with 50mmX80mm port. I selected this design because of its simplicity and size. After some playing around with WinISD and some thinking I have come up with these questions. Any help is greatly appreciated. I did search the forums extensively before posting. I couldn't get some definite answers.
1. Should I use lining on the inside of the box. If so what should I use? Should I use filling?
2. If I use the dimensions for the box as specified in the FE 127E spec should I account for the volume of the driver magnet. After initial calculations I get the volume to be around .3Litres. Should I change the dimensions of the box because of this?
3. Do I need bracing for this box (10L ). If I do use bracing, how should I brace and should I change the dimensions to account for the bracing volume?
Here is a link for the enclosure design. The one on the bottom right corner.
http://www.fostexinternational.com/d...7e_enclrev.pdf
Thanks!
Old 28th June 2007, 09:16 PM   #2
chrisb is offline chrisb  Canada
For a relatively simple, rectangular box, please consider the "GR" version of this series ( fifth set of drawings from the top) :
http://www.planet10-hifi.com/fonken.html
you don't really believe everything you think, do you?
community sites t-linespeakers.org, frugal-horn.com commercial site planet10-HiFi
Old 28th June 2007, 09:28 PM   #3
Scottmoose's Avatar
Yes indeed. Chris speaks words of wisdom: the GR fonken box he links to will blow the Fostex BR cabinet out of the water in terms of quality, and will keep the driver under much better control. There are quite a few other designs lurking around for the 127, of varying difficulty (though none are very hard), which will give better performance than either of the Fostex cabinets. Have a look at these alternatives too, also on Dave's site: http://www.planet10-hifi.com/boxes-fostex.html
Oddly enough, I've just completed the designs for 3 new boxes for the 127, which are about as simple as it gets. Drawings should appear soon, when Dave has time to fire up his CAD software, in between stints of paying work!
If you're set on the Fostex box though, then you won't need to line all of it. I'd do the rear panel, from the top to just below the driver, the top, and one side-wall. That should be quite sufficient. Carpet underlay is a good, cheap material to use. I wouldn't bother to make any adjustments to the dimensions of this cabinet -it's a bit of a compromise, so the differences will be minor. Bracing a small cabinet isn't strictly necessary, but usually worth doing. In this case, if you use a good plywood, a couple of hardwood dowel-rods across the width should do, and another one bracing the rear of the magnet to the inside of the rear panel, which will cut down on box-noise dramatically.
Hope that helps
Scott
Old 28th June 2007, 09:46 PM   #4
Scott
Great; just when I thought I'd have time to finish his kitchen before next month end, you throw this at us. Oops, that was 'spossed to be a surprise - but then again, maybe that means the floor will get repaired in time to install.
Maybe you could take up knitting for a few weeks?
cheers
BTW, without blowing my own horn too much, may I say that I've probably built and extensively listened to more of the multitude of enclosure designs posted on Dave's site than a lot of folks.
In my temporarily not so humble opinion, of all these FE127E designs, including several varieties of bi-poles, the Fonken exhibits the most finesse and overall disappearing act. Nothing's perfect, but these are a pretty decent compromise - within their excursion limits, it's quite amazing the bass "authority" of which this driver is capable.
Old 28th June 2007, 09:54 PM   #5
Scottmoose's Avatar
Did I say 3? Sorry, I meant 4. I forget to mention the versions for the 167 & 207 as well. Oops...
OK, I promise. No more new box designs for a while... although that's probably just giving me time to dream up something really far-out...
Old 28th June 2007, 09:56 PM   #6
Just hold back 'til August, OK
Old 28th June 2007, 10:17 PM   #7
Default Thanks
Thanks for your replies guys.
I can wait I haven't finalized on any design. All I have to lose is a pair of port pipes I bought from Amazon
So this will be a piece of wood connecting the back of the driver and rear inside wall of the speaker? Am I getting the picture? How can I attach the wood to the back of the driver?
Thanks Again.
Old 28th June 2007, 10:26 PM   #8
Default Re: Thanks
Thanks Again.
You don't want to "attach" it permanently to the driver magnet. Cut correctly it will be a pressure fit: I use a small dab of double edge tape or ductseal / blue-tak. Ideally this brace will be at least a U-shaped piece, rigidly connecting at least 3 cabinet panels and the magnet. See the part on Dave's drawings described as "holey brace"
http://homepage.mac.com/tlinespeaker...nkenGR-map.pdf
newbie Q memphissound Multi-Way 7 17th August 2006 11:36 AM
Yet another newbie hell0un1verse Introductions 1 30th March 2006 05:31 PM
Newbie w/ sub ?'s toenail Multi-Way 2 8th March 2003 01:10 PM
Newbie needs serious sub help AcidRain Multi-Way 4 7th March 2003 07:07 PM
newbie post, but hopefully not a newbie question wiredcur Solid State 3 24th August 2002 10:49 PM
Page generated in 0.12277 seconds (75.47% PHP - 24.53% MySQL) with 10 queries
