#1 | |
Hey guys. I searched but couldn't really find anything. If this discussion has already taken place, please refer me to the thread. Thanks.
According to Zaph from Zaph Audio, 3'' is the ideal size for a fullrange driver. He says 2'' have their problems, as do 4'', with 3'' coming out on top. He says: Quote:
What I want to know is whether anyone here disagrees with him, and thinks that 2'' fullranges are just as good as 3'' when paired with a sub. Thanks! |
#2 |
Speakerholic
I certainly lack Zaph's experience and knowledge but I didn't see anything there I disagree with.
#3 |
Seems about right with my findings here too.
#4 |
My 4" TB sounds better than my 3"...
My 4.5" Fostex sounds better than my 4" TB... My 6.5" Fostex sounds better than my 4.5" Fostex... 6.5" is the magic size IMO! Godzilla |
#5 |
Zilla,
My 1.5 inch fullrange or extended range drivers (all 24 of them in a focused array) sound better than many FR drivers at an 8 foot listening distance. Will also go louder than most without breakup or other weirdness. These were Radio Shack close outs and they do sound pretty good. Dan Wiggins measured them as being flat (really flat!) from 275Hz to 20kH. Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#6 |
frugal-phile(tm)
If you ask me, the sweet-spot is 4-4,6"
3" does make a really good mid-tweeter with an added woofer <300 Hz. The field of 2" drivers is not large -- and none do bass so lets call them mid-tweeters... i would like to hear the JXR6, the HiVis & Auras don't get me very excited. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Can you tell us more about your project? How far off axis are the drivers used?
#8 |
I've receintly been comparing 1.5, 2.5,3, 3.5 and 4 inch drivers as satalite speakers, personally my favorites are in the 3 - 4 inch mark, results do depend on the manufacturer! but to me the advantage of some mid bass is noticable, and it ends up being a trade off between quality of mid bass/ treble detail.
#9 |
With a X4 line array, the smaller the driver, the better.
With a 3' i guess the minimum listening distance should be around 4m, and with 2', a little less... Whatever Zaph opinions, I consider that under 4', what you get is a full range tweeter, usable mainly in 2ways set ups crossed in the low mid range. Cone movement is a major issue if distorsion matters... |
| Home theatre - sub + fullranges question! | bezobraznia | Full Range | 30 | 16th February 2008 01:00 PM |
| Deflectors on pistonic fullranges | jzagaja | Full Range | 1 | 8th November 2006 09:15 PM |
| 4 driver line array using fullranges | navin | Full Range | 33 | 8th August 2006 04:45 PM |
| FullRanges into CAR? Help needed. | NonSenCe | Full Range | 1 | 7th September 2005 05:50 AM |
| Newbie:How do I reduce my fullranges midrange ? | ]|[ GorE | Full Range | 4 | 23rd February 2005 05:10 AM |
| Page generated in 0.10617 seconds (72.51% PHP - 27.49% MySQL) with 10 queries |
