Old 18th June 2007, 05:13 PM   #1
Default fr125s + Woofer or Tweeter?
Hi Everyone,
I built a pair of the 7L br enclosures for the fr125s. I'm happy with the sound on simple material (voices sound fantastic!), but I'm not happy with the sound on more complex material (fast paced, multiple instruments).
I was considering crossing the fr to a small tweeter like the 1" aura titanium around 3500hz.
Would I be further ahead to cross to a woofer like the DA175 or RS180 somewhere below 1000hz? It seems to me that I could keep the crossover frequency out of the midrange by doing this.
Any advice would be appreciated!
Old 18th June 2007, 05:33 PM   #2
Scottmoose's Avatar
I'd do the woofer first actually as taking the LF strain from the 125 will improve dynamics no end. I'd look to using a bigger driver if possible though. A 10in unit would be good.
As and when you decide to add a tweeter, I'd suggest not crossing over so low~3500Hz is slap-bang in a fairly critical musical region. 10 - 11KHz would be my choice; well out of the most important musical zones.
Old 18th June 2007, 06:00 PM   #3
Godzilla's Avatar
I recently added a 12" powered sub to my 165k BIBs to good effect... but i also have a super tweeter.
Godzilla
Old 18th June 2007, 07:03 PM   #4
Scottmoose's Avatar
Ye Gods Jeff, I take it you like bass then? Best to add another one to even the room LF SPLs out then...
Old 18th June 2007, 10:21 PM   #5
tinitus is offline tinitus  Europe
Scott, you said it... a woofer would do the trick, but a 10" that match the sensitivity of FR125 is not known to me
I reckon this 8" TB sub would match nicely
http://www.partsexpress.com/pe/showd...number=264-854
Old 18th June 2007, 10:35 PM   #6
Speakerholic
Cal Weldon's Avatar
That TB woofer is good value at that price. In fact it's so cheap you might want to consider a plate amp for better control and perhaps cross the fr at 100 Hz 2nd order?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 19th June 2007, 03:44 AM   #7
Some plateamps go to 200-250hz
Old 19th June 2007, 03:49 AM   #8
gmilitano's Avatar
Hi Andrew,
As others have suggested, I would try the low end first. The lower you cross over, the better. Less than 150Hz. 75-100Hz would be better. As for the tweeter, 10k or so.
Gio.
Old 19th June 2007, 07:56 AM   #9
Scottmoose's Avatar
I wouldn't worry if the woofer is more sensitive than the CSS -better to have too much than too little -you can always loose some if needed.
Old 19th June 2007, 09:56 AM   #10
Sure, a plateamp will mean more freedom in selecting a woofer than with a passive filter
But how about BSC ?
How do I match a woofer and tweeter? chasingame Multi-Way 3 6th August 2009 07:35 PM
Econowave tweeter + which woofer? Godzilla Multi-Way 26 30th July 2009 05:30 AM
4ohm Tweeter & 8 ohm woofer Juggy Multi-Way 2 9th December 2008 01:14 PM
4 Ohm woofer 8 Ohm tweeter Tennessee Jed Multi-Way 4 22nd April 2006 12:13 PM
Woofer/Tweeter Installation firdaus Multi-Way 16 15th June 2005 05:16 PM
Page generated in 0.10122 seconds (78.59% PHP - 21.41% MySQL) with 10 queries
