Hello to all,
after learning that much from here, now its time to give you something back and do my contribution to this forum. I finally finished a pair of CT227 which was developed by Christian Gather and published at KLANG + TON 6/2006, a german diy-magazine. I built it as a birthday present for my sister and she likes the look and the sound - so i see the WAF as given. :-) Since she doesnīt hear music very loud itīs ok that the speakers are beginning to first drop the soundstage and then create distortion at high levels, but for her intended use as TV-speakers for the LCD-panel its really sufficient. The CT227 uses Aurasound NS3-193-8A full-range drivers to create a response of 50Hz to 16kHz via bassreflex if placed ca. 20cm in front of a wall. You can nicely set the bass level and -sound if you move the speakers away and towards the wall. Crossover is built from 0,33 mH 1 mm aircore, 0,1 mH 1 mm aircore, 10 uF Elko, 2,2 uF MKP, 3,9 uF MKP, 2,2 Ohm MOX resistor, 22 Ohm Resistor. The enclosure measures 27,4 x 12,4 x 25,5 cm and was built from 12mm beech plywood. All pieces are rectangular, the bass reflex tube is also made from wood and hidden at the bottom behind the overstanding frontpanel. The surface was 3 times sanded with 120 and 240 sandpaper and finished with beeswax. One word for the sanding: Beech plywood is extremly hard to treat manually so make shure you have proper equipment like a tapped grinder to make life easier. Although i had only 0.5 to 1mm height to correct, it took me about one day to do this manually. No pain - no gain At normal listening volume the sound is balanced and clean, soundstage is wide and voices are not glued to the speakers. Those tiny things made me crouch 2 hours over my floor (since i had no stands) being fascinated by the sound of guitars. The bass is very lightfooted and not thick at all, although it plays deeper than you would think. It depends very much to the music material you play, if thereīs no bass recorded you wonīt hear any. While listening to the synthetic bass of "Trentemoller - moan" a friend said "ok, now put on the new speakers" but they were already playing... Check out my pictures! Ralphono |
#2 |
size comparison
*edit* this pic shows the ct227 fresh sandpapered and without wax on it |
#3 |
back and reflex opening
#4 |
top view with wax
Cheers and regards, Ralphono |
#5 |
Nice. I noticed you said they were hooked up to a TV. In my opinion, these are the worlds best cheap TV speakers. Mine are very similar to yours except they are front ported. I built them over a year ago.
Doug |
#6 | |
Hi Doug,
very beautiful finish on your little ones, i like the black-wood combination and the rounded frontpanel. Looks professional. Quote:
It totally cost 44 Euro for each box and 12 Euro for the complete cut wood. Regards Ralphono |
| New Aurasound NS3 2-way | Timn8ter | Multi-Way | 18 | 16th November 2007 05:05 PM |
| Aurasound NS3-194-8E | Mikael Abdellah | Full Range | 13 | 5th August 2007 04:51 PM |
| Aurasound | Tristanc1 | Multi-Way | 0 | 3rd March 2006 06:37 AM |
| Plans for Visaton Cheap Trick 142 | mr_push_pull | Multi-Way | 13 | 3rd July 2004 01:09 PM |
| Q:cheap trick 142 | Tomac | Multi-Way | 0 | 21st December 2003 07:18 PM |
| Page generated in 0.10820 seconds (71.93% PHP - 28.07% MySQL) with 11 queries |
